www.photomacrography.net :: View topic - Grasshopper Headstudy
PostPosted: Sun Sep 14, 2008 7:59 am    Post subject: Grasshopper Headstudy Reply with quote
This is the eastern cousin to Charles`s Grasshopper 3D Very Happy. One question, why am I getting banding of colors in my backgrounds sometimes. The background is 15" behind the subject (just a wall).
F/5.6
ISO100
Ex .5
Canon 400D, Canon 100mm Macro, 84 images stacked with Helicon Focus
Info the same as above, stack of 43 images
PostPosted: Sun Sep 14, 2008 10:43 am    Post subject: Reply with quote
Nice hopper!
I've seen banding like this with HF "Method B" ever since that method appeared. I haven't studied it very closely, but I suspect it appears when there is variation in background brightness from frame to frame. If this is strobe lit, variations in the strobe brightness from frame to frame could be responsible.
If you are using Method B, then give the older Method A a shot -- it usually does better with hairs and overlapping detail anyway.
And if this already is Method A, I'd like to know that.
PostPosted: Sun Sep 14, 2008 11:55 am    Post subject: Reply with quote
Think basicly, I just use HF right out of the box and I do not change any parameters, so, whatever it is set to by default is how I use it. Right now I am using two lamps that came with a small portable lightbox I bought at a camera store.
Thanks Rik.
PostPosted: Sun Sep 14, 2008 11:57 am    Post subject: Reply with quote
I searched the archives for any more information about the banding. One comment I found (that I had posted and then forgotten! Embarassed ) was that Method B
Quote:
created obvious banding in the background from what had previously been an unnoticed shift in background brightness from back to front of the stack
Perhaps the ambient light in the room was gradually changing as you shot your stack?
PostPosted: Mon Sep 15, 2008 2:44 am    Post subject: Reply with quote
Where do you select method A ? Thanks again Rik.
Doug
EDIT
Opps, I just upgraded to 4.5 and I can see the "Method A & B" dropdown menu showing. Will give them a test next stack.
PostPosted: Mon Sep 15, 2008 5:42 am    Post subject: Reply with quote
Very nice shots Doug! As for banding i thought that was down to jpeg compression.
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Mon Sep 15, 2008 7:53 am    Post subject: Reply with quote
Could be. There are several aspects of the appearance that make me lean toward stacking artifact, but it would take some more investigation to know for sure.
Doug, be sure that HF is set to produce highest quality jpeg output. Reduce quality to meet forum size limits only as the very last step, after all cropping & resizing. That way you can compare before & after to see what got lost. Many tools, like Photoshop, will interactively show you a preview of what jpeg compression will do to your image, so you can pick an appropriate level on the fly. I generally go for the highest quality that still fits in 200 KB.
lauriek
PostPosted: Mon Sep 15, 2008 10:26 am    Post subject: Reply with quote
Lovely shots Doug!
I think the red on the antennae contrasts really nicely with the green on the hopper, personally I might be tempted to do a slightly lower mag stack to get more antennae in the shot..
