www.photomacrography.net :: View topic - Fern's new Frond macro
PostPosted: Sat Sep 06, 2008 3:14 am    Post subject: Fern's new Frond macro Reply with quote
This is my first attempt at proper macro with the 10D plus macro lens.
I set the camera on the tripod, worked out how to use mirror lock up and self timer(that took me a while!)I took a few shots with the camera on Av but they came out a bit too bright. Failing to find exposure compensation while in aperture priority mode I put it in manual and got a better shot!
Vivitar 100mm f3.5macro lens + lifesize adaptor
4 seconds at f16(meter recommended 6 seconds)
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
View user's profile Send private message Visit poster's website MSN Messenger
puzzledpaul
PostPosted: Sat Sep 06, 2008 4:53 am    Post subject: Reply with quote
<< Failing to find exposure compensation while in aperture priority mode ... >>
No idea if this is still the case, but ...
Half press shutter to display v/finder info (if not already there)
Then just rotate main (knurled) command wheel on back of cam to suit - eyeballing exp comp scale in v/finder.
(Can set to 1/2 or 1/3 steps, btw via custom functions)
pp
Boxes, bottlebottoms, bits, bobs.
augusthouse
PostPosted: Sat Sep 06, 2008 5:05 am    Post subject: Reply with quote
Larry,
I am finding as much enjoyment looking at this photograph as you must of had in taking it. You seem to have sorted out that 10D nicely.
What you have captured here is special.
The long reaching 'arm' of the frond, the partially open 'hand' at the end, and the balance the recently opened segment brings to this photograph are reminiscent of Karl Blossfeldt.
They are my first thoughts. Love it!
PostPosted: Sat Sep 06, 2008 5:17 am    Post subject: Reply with quote
pp
Ah spot on there, thanks for that(I just tried it,I'll know better next time!)
augusthouse wrote:
Larry,
Wow thanks Craig, being compared to Blossfeldt means a lot as I studied his work at college!
