I was passed this tiny beetle to ID. Several were found in a medical factory clean room causing problem.
It turned out to be a Red flour beetle Tribolium castaneum.
Took this photo using a ping-pong ball defuser. Not too sure of the results.
Nkon D200
Nikon CF N Plan Achro 10x Objective on bellows
Approx 50 photos stacked with HF
Red Flour Beetle
Hmm... I think the lighting is a bit too even and adding the grey background, it makes the image look kinda flat. Other than that, it looks pretty darn good.
I have a question though... Sometime I see |______1mm_______| in an image here, how do you guys find out the exact scale?
- microcollector
P_T
I use a Meiji EMZ-5TR scope for my mineral photography. The zoom range is from .7 to 4.5. At each of the numbered zoom increments I have determined how many millimeters the horizontal field of is. I place a millimeter scale on the stage, go to live view and record the FOV for each setting. In Photoshop, I add a scale bar that represents 1/4 of the FOV.
Doug
Doug
micro minerals - the the unseen beauty of the mineral kingdom
Canon T5i with Canon 70 - 200 mm f4L zoom as tube lens set at 200mm, StacK Shot rail, and Mitutoyo 5X or 10X M plan apo objectives.
My Mindat Mineral Photos
http://www.mindat.org/user-362.html#2
