Hi there,
Thanks to Rik and Charlie for clarifying the points on colour temperature in mixed lighting situations.
Up to now I've always used flash for my macro work. I usually set my cameras to the flash preset colour balance, and then adjust it if necessary when converting from RAW.
If I can get these photo floods I have up and running, I would try the tungsten preset to test the results. If it wasn't very good, I would create a custom balance for each setup.
I had in mind to use a low power flash, with or without filters, for background illumination. Not sure entirely what that would do to the colour balance.
Thanks for the comments.
Bye for now
Power Control For Tungsten FLood Lamps
- georgedingwall
