Butterfly stack
nto
Butterfly stack
Post by nto »
I had this butterfly by two months, found with spider :D , today decided to make the stack, I was interested in the outcome of tufuse areas with extremely bright, with slight under exposure I got result set, composition and not better, but this new world for me.
result of tufuse without post production
100% crop of the first image
final result
Technical info:
350d
extension tube 25mm
105mm set to f/6.3 at 1:1
nikon af 50mm f/1.8D reversed set to f/4 at infinity
two flash wtih diffuser , see here
30 frame step 0.1mm
aligned with CombineZM, stacked with Tufuse
ciao
Antonio
P_T
Post by P_T »
Oh that's beautiful!! I wouldn't mind seeing a deeper stack though. :D
lauriek
Post by lauriek »
Gorgeous!!
Do you know what species of butterfly it is?
nto
Post by nto »
Thanks Guys,
I think Pieridae: Pontia daplidice or Euchloe ausonia, I do not know
Antonio
augusthouse
Post by augusthouse »
Outstanding Antonio!
dmillard
Post by dmillard »
Nice images Antonio - excellent composition, and you have succeeded well at capturing the fine detail of the hairs surrounding the head.
David
nto
Post by nto »
Craig, Outstanding is good when other elements balanced composition
David, I see better days after photo, composition I like best
Thanks Again
Antonio
acerola
Post by acerola »
Well Done. I like it.
Péter
Post by Cyclops »
Excellent shots,looks like one of the blue butterflies to me. Whats tufuse?
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
nto
Post by nto »
Larry, tufuse Verison 1.34, left eye a little blue, taken reflected light metal setup (still under construction :D )
Antonio
