Yellow Jacket portrait
rosemarie
Post by rosemarie »
Found a dead yellowjacket and brought it indoors to practice on. This image is cropped to about 50% (area) of the frame, chiefly because I don't know what to do with the OOF wings, leg, etc. that were outside the planes of focus that I used. I removed dirt specks and what I think were artifacts from CZM, and I added the background in the top corners.
Sony H9, 210-mm equiv + 50-mm Nikkor reversed @ F/2.8;
32 exposures about 250 microns apart: F/4.5, 1/5 sec, iso 100 (EV +.3), tripod, remote, & Manfrotto "micropositioning plate"
CombineZM @ Do Stack + weighted avg correction
This is only the 2nd macro stack I've done, so I'm seeking all the criticism, comments, and suggestions that you're willing to give me. --Thanks!
rosemarie
P_T
Post by P_T »
It looks nice and sharp and I love the eyes!!
If you don't mind a little critique, I think the lighting is a bit too strong and the top part is a bit out of focus, perhaps it might be better to take more photos for the stack so that the bee outline is more defined?
acerola
Post by acerola »
Hi, Not bad for a first post.
I think you can improve on the lighting. It is a little strong. There are some places where no details left. Lighting is one of the hardest thing. You have to use more diffusion, especially for shining subjects. Like paper towel or something white, i don't know the proper English names, you can read back its an evergreen topic.
The picture is a little crumpled for me. But it depends what do you want to achieve. And maybe you can think about using some background.
Péter
nto
Post by nto »
I agree to experiment with soft light, the central quality seems good, perhaps too 210mm compress perspective, or subject compressed?, tried with focal smaller and 50mm at f / 4?, quality board enough?
Antonio
rosemarie
Post by rosemarie »
Thanks for your comments. The light may be harsh because my first experiments didn't have enough light and because I probably increased the contrast too much working on the CZM result. I never would have thought that the 210-mm would distort the subject, but now that you say so, "of course." Two lessons learned, with thanks!
rosemarie
I'm not sure whether this particular image is distorted very much, but since the subject has been raised...
It is definitely possible to get some strange perspectives with these "stacked lenses" setups that place a short lens in front of a long one.
Depending on gory internal details of the lenses and how they are used, you can end up with anything from an extreme "wide-angle" effect where closer portions of the subject are magnified much more than parts farther back, to even a "reversed perspective" effect where closer portions of the subject are magnified less than parts farther back!
Under certain happy circumstances, a setup with stacked lenses may accidentally form a "telecentric" system in which magnification does not depend on distance at all. Such systems are occasionally useful for esoteric work like stack-and-stitch at moderate magnifications.
Harold Gough
Post by Harold Gough »
Any change in lighting might include some directional element to show the two posterior ocelli better.
Harold
