I calibrate my monitors with Eye1 (colorimeter) and iMatch (software) from Gretag-MacBeth. But it is a software calibration, i.e. the parameters of the video card are changed. For me this is sufficient right now.lauriek wrote:These look a lot better to me!!
Does anyone here actually run calibrated monitors (I mean calibrated with a proper hardware dongle, not by eye) and if so what hardware do you use, and how do you find it?
Craig how easy do you find the S3 to use, and do you recalibrate regularly?
The much better solution is, of course, hardware calibration where the parameters are written to the LUT of the monitor itself. However, these monitors are much more expensive.
My EIZO 2431 cost a bit more than 700 EURO. The one I would have liked but could not afford (EIZO CG241, which allows hardware calibration) ) costs twice as much.
There are several options for calibration devices: GretagMacBeth, Spyder, Monaco, basiccolor, EIZO offers its own software (color navigator). etc. They all are around 250-300 EURO (colorimeter + software) at the moment. Probably the best affordable software currently is that of basicolor. They have their own colorimeter but it also runs with Eye1 (being the same build).
In my opinion it is worth the investment. Initially I calibrated my monitors with Adobe Gamma and was astonished how different everything looked when I first used a colorimeter.
But be prepared - color management has a certain learning curve.
Cheers
