Hello all,
I need help finding a source for the bellows. I have a Sony a100 and a Tamron 90mm macro lens as well as an assortment of Minolta lenses which may or may not be of any value for the macro photography. I am not too interested in ebay.
As always, thanks for all your knowledgeable assistance.
Gary
A source for bellows
Gary,
You seem to assume that your 'macro' shots would require a bellows. You also propose to use the 90mm lens which many of us find excellent for close-ups down to moderate macro.
For the above range, I use the 90mm Tamron with a x2, matched, teleconverter for up to life size magnification and good working distance. Tamron make a matched tube too give life size (1:1) reproduction with that lens, which eliminates any losses from additional lens lements (teleconverters).
For higher magnifications you might consider a bellows lens, using it with additional extension tubes or a bellows.
Don't condemn eBay too readily. Over the last six years I have obtained, via eBay, some rare/highly desirable lenses and macro flash equipment, etc., without which my flexibility, especially in the macro range, would be somewhat curtailed.
Harold
Harold
