linos lens 105mm F 5.6 need help
I was wondering if some one might know. If Rafe is still making attachment rings. This linos lens is 45.89mm in dia. Would some one here know where i can get a mount for this lens. Here is and image of the lens
Rocky Carter
Re: linos lens 105mm F 5.6 need help
I see no indication of an image. Did you forget to Submit an upload or link to one?
Doesn't the 105/5.6 feature a Schneider Optics V-groove dovetail mount? I could be wrong.
If I'm not, an original Schneider adaptor that converts the dovetail to M42 can be had for around $50 used. Not cheap but you do get Schneider's quality.
The Schneider mounts are V38, but the Linos 5.6 inspec.x mounts are a larger V46. I've used the 43mm filter threads to attach my copy, but finding a V-mount adapter would be better long term.Macro_Cosmos wrote: ↑Sat Jul 18, 2020 4:36 amDoesn't the 105/5.6 feature a Schneider Optics V-groove dovetail mount? I could be wrong.
He does have 46mm clamps of various kinds https://rafcamera.com/catalogsearch/res ... 46mm+clamp
I would like to thank all of you for your help. I finally got this lens mounted by using masking tape. This lens is incredible. I can see I need to build a dimmer switch for this lens. I am going to try to upload a photo. Wow is this lens revealing. Thank you all very much
Rocky Carter
Yeah it's a good lens, wait till you try the 3.5x rayfact of 3.3x 100mm F4 Linos
