Image hosting procedures: the short story
We offer image hosting in the galleries to all of our members. Please review these simple procedures to host your images in your topics.
Re: Image hosting procedures: the short story
Lou Jost wrote:
Thu Jul 09, 2020 12:01 pm
Rik, I tried to upload an image 259kb, 1000x952px, but I get an error flag saying the image is too big. Did so again here in this thread, with the same result.
Lou, I found one discussion that says
The .jpg image can contain the original dimensions in the EXIF data. When a file is edited the software may not alter it. phpBB is reading the EXIF data instead of determining the the actual dimensions of the image. Saving as .png or .gif will strip the EXIF data. If you "save for web" or specifically remove the EXIF data in the .jpg the issue goes away.
What was the workflow for generating your image? Can you check specifically what the EXIF says? Something like "exiftool -a -u -g1 foo.jpg" should get all the tags
Will do Rik, thanks. For what it's worth, I had no trouble uploading a similar-sized file to a PM this morning.
Edit- Just saw your second message. I shrunk it from a larger image. However, as I mentioned, the server did list the correct size, right next to the error flag saying it was too big.
Image has been sent, Rik.
rjlnorm
Post by rjlnorm »
Lou -- problem fixed, it seems. Please re-try the upload yourself.
I found and removed a "feature" in the standard phpBB distribution, that was apparently "resizing" images to plupload quality 85%, even if the pixel count and file length were already within limits. This had a plethora of possible side effects, including altering image quality and color profile. I'm guessing it was the cause of the color profile oddness discussed HERE.
I have now tested several image files and observed that the file uploaded and the file subsequently downloaded are binary-equal. It's a bit humbling to think that I must not have run that test before.
I have also added this mod to the tidy little procedure of only 46 steps, in my notes for doing the upgrade to phpBB 3. But almost certainly that count is too small, since I'm pretty sure I have failed to record some steps, and I rather doubt that the process is done yet.
Please let me know whatever else you notice that is odd.
Edit: resizing seems to be done on client side by plupload, versus server side by imagemagick. Or maybe it's done either place, depending on browser capabilities. This stuff is all too complicated for me to quickly understand in any detail.
It worked for me now in the original trhead. Thanks for fixing it!
Excellent. Thanks for calling my attention to this problem.
Billy B
Post by Billy B »
I'm new to the forum and would like to post a few photos, however after processing a photo through Export in PS and re-sizing it to 1024x 674, the KB is almost 600 KB and not the 300 you mention in the beginning of your post. Any suggestion's ? Great site with a lot of helpful photographers'....
Billy B wrote:
Thu Jul 23, 2020 7:04 pm
In the current Photoshop, the best menu entry is File > Export > Save for Web (Legacy).
In the dialog that pops up, near the upper right corner there is a "Quality" field, which contains a number ranging from 0 to 100. Near the lower left corner of the same dialog, just underneath the image panel, there are a couple of lines of text that give the estimated file length and transfer time. I have outlined those here:
The trick is to adjust the quality number so as to make the length number be a little under 300K. A simple way to do that is to highlight the number in the Quality field, then press the up-arrow or down-arrow keys to adjust the Quality number, while watching the number for file length. When you finally get length to be the right value, then click the Save button. It's always best to check the actual length as shown by an operating system file browser, since Photoshop's number is a little off sometimes.
Billy B
Post by Billy B »
Thank you Rik. I'll let you know how it works.
Post by Chris S. »
rjlittlefield wrote:
Sat Jun 20, 2020 11:51 pm
. . . (To determine the URL of an image that is attached to another post, use your browser's function to "Open image in new tab" or its equivalent (the exact name varies between browsers), then copy the URL from that new browser tab. It will be something like "https://www.photomacrography.net/forum/download/file.php?id=123"
In Firefox, and easy way to get the URL of an image in another post is to right-click on the image, choose "View image info", and copy the text displayed to the right of "Location:".
Duke
Post by Duke »
Hi, Rik.
Is there a way to overlay url link for original uncompressed image onto attachment? Can't get it to work with php TAGs.
Clickable attachments would be much more convenient.
Thx.
“Thoroughly conscious ignorance is the prelude to every real advance in science.” - JCM
Duke wrote:
Mon Mar 01, 2021 1:55 am
There is no way to do that, as far as I can tell. Attempting to place an attachment tag inside a url tag generates broken HTML. Postings in the phpBB support forums suggest that this behavior has roots deep in the phpBB tag handling software, which is a total black box to me. In the support forums I see no movement in the direction of getting it changed to work the way we would like.
The best workaround I know is to put the link on nearby text, something like "Click HERE for more detail", that is outside the attachment tags.
One caution: be aware that there is a trick that can give the illusion of working properly, but then break without warning a short time later. That bad trick is to upload an image as attachment, retrieve the URL of the attachment, and change the tags from "attachment" to "img", then wrap the img inside a url. This may work for a while because of caching of attachments. But changing the tags from "attachment" to "img" also makes the attached file an "orphan". Some time later, without warning, the orphaned attachment will be deleted from the cache. After that, the post will show at best a clickable broken image icon, certainly not the desired result.
JonyWest
Post by JonyWest »
Thanks for the explanation! Will definitely try it.
Scarodactyl
Post by Scarodactyl »
JonyWest wrote:
Wed Aug 25, 2021 1:36 pm
This guy is a spambot, see how his previous post is edited now. Sorry to post about it, there doesn't seem to be a report button.
Scarodactyl wrote:
Wed Aug 25, 2021 3:42 pm
Thanks for the heads-up. His account is disabled now. I've deleted his post in the other thread, which had been edited to link to a non-relevant website.
You're correct that there is no "report" button. We deliberately turned that off because historically this forum has not needed the function enough to justify the clutter. That may change if these spambots get much more clever.
