Stonemaster Stackmaster
Did a search and only found only one mention here to the Stackmaster rig (from 2017). Has anyone used this system and if so, any comments or critiques?
- enricosavazzi
Re: Stonemaster Stackmaster
I know nothing about it, but as a reference the Stackmaster is made/marketed by a company called Stonemaster, which also advertises lapidary equipment:dhmiller wrote:Did a search and only found only one mention here to the Stackmaster rig (from 2017). Has anyone used this system and if so, any comments or critiques?
https://www.stonemaster-onlineshop.de/
They also advertise a bigger system, which they call StackUnit, containing the Stackmaster and other equipment:
https://www.stonemaster-onlineshop.de/f ... 3961045596
Hello,
Many users of the StackMaster can be found in the following forum:
https://www.stonemaster-forum.de/
BR, ADi
BR, ADi
It is strange.enricosavazzi wrote:I know nothing about it, but as a reference the Stackmaster is made/marketed by a company called Stonemaster, which also advertises lapidary equipment:dhmiller wrote:Did a search and only found only one mention here to the Stackmaster rig (from 2017). Has anyone used this system and if so, any comments or critiques?
How can they sell it without a global web site?
Regards.
Omer
Omer
- enricosavazzi
It could indicate that they are not interested in selling globally. Maybe the German market is enough for them.lonepal wrote:It is strange.
Hello,
I´m a happy user of the Stackmaster...
Some information on the stack unit (including the stackmaster) can be found here:
https://www.mindat.org/article.php/2254 ... ing+Device
and here:
https://www.mindat.org/article.php/2089 ... chronology
The rail is very much intended for studio work and rather heavy duty. Due to a reduction gear precision ist very high and the rails accepts higher loads than most competitors. It does not come with a manual controller box as compared to the StackShot or Novoflex Rail, but is controlled by a PC software (Windows or Mac). As far as I know the software supports the English language as well.
Rainer Ernst (the guy behind Stackmaster) also sells various stands and a brilliant LED lamp (an early iteration of which is mentioned in the link above).
The main reason for me to opt for the Stackmaster was the fact that the company is about 1 hour drive from my home, so I could pick the system up myself and would have the option for local support. I suppose a lot of the user base resides in Germany but there are definitely international users, too.
Best regards
- Björn
and here:
Best regards
- Björn
It looks like a great system but it comes with a hefty cost. I would guess shipping outside of German would be a forbidden cost on top of the already high pricetag. If you're in the USA, you should be able to build something very similar with $2800 (about 2550 euros) using surplus items. Start with a heavy slab of granite/marble, optical breadboard on top...
What are your intentions? Curiosity or is there an actual goal you have and the stackunit ticks many boxes?
I love the cable management they have, mine looks like a network switchbox maintained by an intern... however, I don't see transillumination support along with some other lighting methods I like to utilise.
This however looks interesting: https://www.stonemaster-onlineshop.de/s ... 2829123896
Looks like a nice table top unit to create thin sections indoors.
They have shipping costs here: https://www.stonemaster-onlineshop.de/j ... dab6cd88b3
That's quite the tag.
