Crab Louse in darkfield and DIC
WalterD
Post by WalterD »
Subject louse (Phthirus pubis) was examined as follows :
1 Darkfield - Leitz NPL Fluotar 6,3x , unmounted
2 DIC - Leitz 10x/0.45 oil immersion, mounted in euparal
3 Leitz NPL Fluotar 6,3x/0.20 in euparal without coverslip
4 Leitz NPL Fluotar 16x/0.45, mounted in euparal
5 Leitz NPL DIC 25x/0.50, mounted in euparal
6 Leitz NPL DIC 100x/1.30, mounted in euparal
2,3 and 4 were taken with non-dedicated DIC objectives, "pseudo DIC".
Thanks for looking.
houstontx
Post by houstontx »
First image is very dramatic! All images are great, I love it. Interested to see your Leitz DIC (ICT?)setup.
Robert Berdan
Nice pictures
Post by Robert Berdan »
Hi Walter very nice pictures thanks for sharing.
Rob
WalterD
Post by WalterD »
Thanks both for your positive remarks.
@Houstonx: below a couple of pictures of my DIC -indeed ICT- setup.
Center is an Ortholux II ( the "new" Ortholux) with an eyepiece head designed for 30mm diameter eyepieces. This results in a field number of 24, where the standard FN is 18. So it catches a larger part of the image.
The revolver and condenser are made for DIC, the condenser also has phase contrast stops that I did not use yet. The objectives were mounted in fixed (optimal) position in the revolver in Leitz factory.
Since a couple of months I've been using a mirror house, which makes it possible to switch between flashlight (speedlite) and 10 W Led.
Regards,
Walter
Walter, very nice pictures!
An interesting microscope you have. I see an afocal arrangement. Are you using a Canon pancake 40mm lens over a Periplan 10X eyepiece?
Saul
Post by Saul »
Impressive photos, very nice light on #1
Saul
μ-stuff
WalterD
Post by WalterD »
Hi Pau and Saul, thanks for your positive remarks!
@Pau; yes correct it is an afocal setup, identical to the setup with the Orthoplan I posted a couple of years ago in equipment discussions. The camera lens is indeed a pancake and the camera is hanging on the ceiling with a beamer support, so different microscopes can be positioned underneath it.
The eyepiece is a 6,3x Periplan, the same you've been using in your first post in this forum "Diatom in Darkfield" (2010). That was very helpful to me to arrange my setup.
Regards,
Walter
Walter, thanks for the follow up, this is an interesting setup, I now remember your original anti-vibration system
Nice set! I'm partial to the darkfield myself, very 3-dimensional and great light light on the upper surface (is the body somewhat translucent?)
WalterD
Post by WalterD »
Hi Charles, thanks for your positive response!
Charles Krebs wrote:Nice set! I'm partial to the darkfield myself, very 3-dimensional and great light light on the upper surface (is the body somewhat translucent?)
The body is a rather translucent indeed, small insects are therefore good to combine with darkfield. I do like experimenting with darkfield, next post will be diatoms again.
Regards,
Walter
