www.photomacrography.net :: View topic - Polarized Reflected UV Photography
kds315*
PostPosted: Mon Apr 06, 2020 5:44 am    Post subject: Polarized Reflected UV Photography Reply with quote
Today (after some too long hiatus) a bit about Polarized Reflected UV Photography, using a PHLOX - Rockfoil flower and a deep reaching (up to 320nm) circular polarizer in front of a Baader UV filter (320-390nm). Multiple images assembled into a animated gif.
Phlox flower in M-mode i.e. non exposure compensated:
Phlox flower in A-mode i.e. exposure compensated:
These are some early experiments, of course there is room for improvement, like stacking each pol filter position to get more DOF etc. but first things first...
Klaus
kds315*
PostPosted: Tue Apr 07, 2020 7:12 am    Post subject: Reply with quote
Here another example (white Saxifraga flowers), which shows the predicted effect my friend told me about: That bees have around their eyes sensors able to detect polarized light and there woud be flowers using that:
Visible Light - Sunlight:
Reflected polarized UV, only sunlight:
Reflected polarized UV, using a 365nm UV LED:
Klaus
Macro_Cosmos
PostPosted: Tue Apr 07, 2020 9:16 am    Post subject: Reply with quote
Interesting results! Reflected polarised light and in UV, looks very trippy.
I've been doing some PPL/XPL stuff recently. I'm thinking about automating the polariser's rotation so I can do video. A rubber wheel that's pushed against the polariser, should work out very well.
Personal Flickr page: https://www.flickr.com/photos/133023063@N04/
Blog still under construction
kds315*
PostPosted: Wed Apr 08, 2020 1:13 am    Post subject: Reply with quote
Ineresting idea to automate that!!
Klaus
kds315*
PostPosted: Sun Apr 12, 2020 5:18 am    Post subject: Reply with quote
Polarization is an effective tool in photography and cross-polarization is well know to allow to suppress shine and reflections from certain surfaces.
Here a few tests I have made after having been able to find suitable UV polarizers using a glass vase standing on an aluminum lab jack.
Visible light on top, reflected UV light at bottom. Zero, 45 and 90 degree polarizer angles (left to right).
Klaus
kds315*
PostPosted: Wed Apr 15, 2020 5:27 am    Post subject: Reply with quote
So today about Lewisia - Cliffmaids in reflected and polarized light
Klaus
MarkSturtevant
PostPosted: Fri Apr 17, 2020 9:29 pm    Post subject: Reply with quote
That is very interesting. I know that some flowers will use UV reflective colors to communicate with bees. Some have stripes or other patterns as 'guides' to lead bees to the center -- communication between flowers and bees that we don't normally get to see.
Mark Sturtevant
Dept. of Still Waters
kds315*
PostPosted: Sat Apr 18, 2020 9:35 am    Post subject: Reply with quote
Thanks, yep indeed they do use this.
Klaus
kds315*
PostPosted: Sun Apr 19, 2020 11:50 am    Post subject: Reply with quote
Well this is a bit on the scientific side, sheet Mica in polarized UV and visible light, different pol. angles.
If interested about the colors and why, I refer to the work of Mr Michel-Levy https://en.wikipedia.org/wiki/Polarized_light_microscopy#The_Michel-Levy_chart
Klaus
kds315*
PostPosted: Wed Apr 22, 2020 1:09 am    Post subject: Reply with quote
Different approach used here, delivers more intense colors...
Klaus
