www.photomacrography.net :: View topic - StackShot vs MJKZZ Qool
Quatz
PostPosted: Fri Apr 03, 2020 3:12 am    Post subject: StackShot vs MJKZZ Qool Reply with quote
I am considering purchasing an (automatic) macro rail. I have two rails on my list.
- Stackshot macro rail
- MJKZZ Qool 250
Over both I read good messages.
As stacking software I use Zerene on my iMac. I want to use the rails horizontally as well as mounted on my tripod
So I am looking at the differences between these two rails.
The Stackshot is readily available (in the Netherlands) and can work together with the Zerene software. I have read that the Stackshot is easier to use than the Qool. However, I cannot find out where that difference is.
I have to order the Qool rail via Germany, it cannot be connected to my iMac via USB, does not work together with Zerene, but it is significantly cheaper.
Although I don't want to pay a top prize, I find ease of use important.
Any advice / comment on this?
JKT
PostPosted: Fri Apr 03, 2020 7:12 am    Post subject: Reply with quote
I suppose it depends on how much you intend to use it. For occasional use it would be easier to put up with non-trivial workflow, but for regular use I'd take easier workflow if I could afford it.
Quatz
PostPosted: Fri Apr 03, 2020 8:24 am    Post subject: Reply with quote
Yes agree, and how much easier would it be?
PostPosted: Fri Apr 03, 2020 8:46 am    Post subject: Reply with quote
Another option worth considering that works with the iMac & PC like the Stackshot, and also Smartphones, is the Wemacro Rail, probably one of the better overall values in focus stacking rails available.
~Mike
Quatz
PostPosted: Fri Apr 03, 2020 9:34 am    Post subject: Reply with quote
I have seen the Wemacro but it is not directly available in the Netherlands
