Well this didn't turn out that great due to the thickness of the EPROM cover glass. For a larger version click the link below. Once there, if you click on the image, give it a second or two to load, then you can pan around a much larger image. The larger image is much better.
https://squattingdog.smugmug.com/Semico ... -BjVHPRN/A
-JW:
Erasable EPROM F2708 8022 UV Singapore - 1975
Thanks. I was quite surprised with the outcome seeing how thick this particular glass cover was. I too have several and have failed removing the glass with this particular design.Macro_Cosmos wrote:I have several vintage eeproms and eproms of this kind, tried removing the cover and failed spectacularly.
Nice shot!
-JW:
