www.photomacrography.net :: View topic - Dead pixels?
Dead pixels?
Harald
PostPosted: Wed Mar 25, 2020 11:53 am    Post subject: Dead pixels? Reply with quote
Hi there good people..
I have been using Zerene Stacker for some years now.
Very happy with it. It does a wonderful job with my minerals and insects..
One question:
I get some red and green short stripes, is this dead pixels?
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
PostPosted: Wed Mar 25, 2020 8:51 pm    Post subject: Reply with quote
Probably these are hot pixels. Hot pixels behave normally for short exposures, but get "bright" for long exposures because they accumulate charge from electrical leakage in addition to light.
There's a new feature in Zerene Stacker that applies here. See https://www.photomacrography.net/forum/viewtopic.php?t=41343 .
Harald
PostPosted: Thu Mar 26, 2020 12:36 pm    Post subject: Reply with quote
Yeah,
If you can afford pro version....
Kind Regards
Harald
AFIAP / CPS
BGF / GMV
PostPosted: Thu Mar 26, 2020 2:20 pm    Post subject: Reply with quote
Otherwise the standard approach is to add light, so as to enable a shorter exposure at same ISO setting. (Shortening the exposure by increasing the ISO setting is not effective, because that approach does not change the ratio of light to leakage.)
If you have other tools that support context aware filling and some sort of batch automation, such as Photoshop and GIMP, then you may be able to use those tools to pre-process your source images by masking the hot pixels and replacing them with nearby content, before stacking the results.
Unfortunately I do not have a recipe available for exactly how to do that.
Edited to add: for GIMP, consider using Heal Selection (Resynthesizer) as described at https://patdavid.net/2012/08/getting-around-in-gimp-heal-selection.html .
Harald
PostPosted: Thu Mar 26, 2020 2:32 pm    Post subject: Reply with quote
What speed do you recommend?
You do a wonderful job on The Zerene Stacker my friend.
I've been using for some years now and I've recommend it to other I know.
A friend og mine working at The Norwegian University with photographing insects. I made him switch from Helicon Very Happy
Kind Regards
Harald
AFIAP / CPS
BGF / GMV
PostPosted: Thu Mar 26, 2020 8:51 pm    Post subject: Reply with quote
I cannot make a specific recommendation about speed. Too much depends on the sensor and operating conditions, for example whether Live View is being used which makes the sensor get hot. You will have to run your own tests.
With my Canon T1i camera (yes, I know, an ancient sensor), at 1 second there are maybe 6 annoyingly bright hot pixels, at 5 seconds it grows to more like 35, and at 30 seconds the mask I made has over 150 spots.
BTW, another attack on hot pixels, if you are shooting raw, is to use a raw converter that can be told about defective photosites. dcraw and any of its derivatives come to mine. Again I have no recipe at hand.
Thank you for the kind words about Zerene Stacker. I am hoping that you merely had to illustrate its advantages for your friend, with no coercion required. Rolling Eyes
Bob-O-Rama
PostPosted: Tue Mar 31, 2020 1:24 pm    Post subject: Look fo hot / dead pixel mapping in camera Reply with quote
Many modern cameras include built in hot pixel / dead pixel mapping. If your's does, you can run it and not worry about it for a month or so. If you already have a series you want to repair, this is surprising easy to do with Image Magick and some light weight scripting. Once you identify the (x,y) of the wonky pixel, you can have ImageMagick replace it with a average from surrounding pixels using their pixel math stuff.
-- Bob
-- Bob
https://bob-o-rama.smugmug.com/
