www.photomacrography.net :: View topic - Wild 439168, part of what?
Rorschach
PostPosted: Wed Mar 18, 2020 8:51 am    Post subject: Wild 439168, part of what? Reply with quote
Does anyone know what outfit this one belonged to originally? It looks like a part of the Wild discussion stereomicroscope, but the part number does not match. I have a pdf brochure of the Wild stereomicroscope discussion system and checked the numbers.
The column is very thick. I wanted this unit because of the fine focus capability which is lacking from a Wild M8 normally. It should mate with the M8 without much problems, I think.
Do not worry, I paid much less than what you can see in the pic Very Happy
Rorschach
PostPosted: Mon Mar 23, 2020 12:53 pm    Post subject: Reply with quote
Mystery solved. It is indeed part of the discussion microscope setup.
I found the reference and the part numbers in a Wild M3 series brochure from late 80ies. So the part number has changed from that which was seen with M8, M7 and so on.
