Hello,
I would like to enhance the macro abilities of my mobile phone. I don`t want to convert it into a microscope (no 10x lens) but push it a little further. I handheld an achromat (4x I think) before the mobile camera and that works quite well.
Absolutly cool would be when an adapter also could use the LED Illumination of the phone and transfer/diffuse it for the close macro range.
Can anybody recommend some brand/type of those auxillary lenses?
single lens clipped by rubber band
multi element clip on design
5 element design allows bigger working distance
regards
Lothar
macro lens for mobile phones
I got this lens from Aliexpress called a 100mm macro lens.
For under 15€ I'm very happy with the quality, solid metal clamp with rubber sheets to protect the phone. On an iPhone 11 I get 32mm picture width instead of 70mm without the lens, working distance is still 4cm with the lens attached.
crop
crop
I haven't tried this one since I own a Galaxy. I've seen them on eBay.
https://www.dearsusan.net/2017/04/28/ze ... bbit-hole/
Would be nice to see some actual comparison test from a non sponsored individual.
https://www.digitalcameraworld.com/buyi ... oid-phones
-JW:
-JW:
I second lothman post, Apexel lenses are ok; other brands have similar..
Your 5-elements seems ok.
Get one around 20$ from Aliexpress, or the same model from ebay.
I have an clip-on 25mm Apexel always in my pocket!
The Autofocus tracking of the phone works a beauty...
Beware that the lens by lothman fits the Iphone, but may not fit f.ex. Samsung Galaxy, because the camera is too distant from the border; you need a longer clip.
All macro lenses are pretty strong, short working distance; I haven't found any weaker lens.
No way to get the flash light... they are all too large and get in front of it.
I recommend to AVOID:
- the 2-in-1, 3-in-1 or 7-in-1 sets, they have low resolution and the macro lens is just 1 lens.
The "rubber band" is the same.
- Expensive models from cool western brands, they are just rebranding of the Chinese optics at 4x the price, with some fancy mount. Exolens may be the exception, but they seem expensive or out of commerce.
Did you try other lenses, like 2x tele, wide angle ?lothman wrote:I got this lens from Aliexpress called a 100mm macro lens.
I got this macro also, very happy with it (comparing with previous I purchased), except one small problem - hard to take out the lens from the silicon case
Yes, 37mmMacro_Cosmos wrote:It even has filter threads! Time to mount an objective lens onto it just for fun.
Saul
μ-stuff
μ-stuff
no I did not try other lenses but I bought another sets of the APEXEL HD optic camera 100mm macro lens.Saul wrote: Did you try other lenses, like 2x tele, wide angle ?
And yes the lens is sticky in the silicon case but on the other hand it is a good protection. If they only could make some small nibs (shackle whatever) on the silicone part so that you can attach the metal clamp, than everything would stay together.
