www.photomacrography.net :: View topic - Psychedelic Bubble Soap Photography
fisheyeadventures
PostPosted: Sat Jan 11, 2020 9:23 am    Post subject: Psychedelic Bubble Soap Photography Reply with quote
Hey everyone
Quick and simple macro photography tutorial you can try yourself at home. I took psychedelic images with water and soap. Using water, dish soap, a tripod, a bright light, a glass and a macro lens you can take colorful images by yourself. I am working on a second part focussing on quite similar images taken with a flash getting even greater and sharper results.
Have you ever tried to captures those images? Which settings and setup did you try?
https://youtu.be/BLfMTCGG3xY
Admin edit [rjl]: URL format
Youtube-Channel:https://www.youtube.com/channel/UCIZpKZH73Xr8udmjGmzp_IA
Insta: https://www.instagram.com/jns_hdlr/
Sumguy01
PostPosted: Sat Jan 11, 2020 2:58 pm    Post subject: Reply with quote
Very Happy Very interesting.
Thanks for sharing.
David Sykes
PostPosted: Mon Jan 13, 2020 5:51 am    Post subject: Reply with quote
Very hypnotic, takes me back to my misspent youth for some reason Very Happy
If you have a lens with a large enough image circle and have a means of tilting the camera body that would bring the entire plane of the soap film into focus.
Olympusman
PostPosted: Mon Jan 13, 2020 2:25 pm    Post subject: Soap bubbles Reply with quote
I played around with soap bubble photography a few years ago. I made 4x5 inch sheet bubbles.
http://www.microscopy-uk.org.uk/mag/indexmag.html?http://www.microscopy-uk.org.uk/mag/artmay08/mm-bubbles.html
fisheyeadventures
PostPosted: Thu Jan 23, 2020 3:52 am    Post subject: Reply with quote
Thx4sharing your setup, great results!!!
