In all the discussions about the DImage 5400 lens, did we ever determine it's actual resolution subject-side (smallest resolvable distance in microns)?
I've scouted around on here and wasn't able to find any numbers. Even a theoretical/calculated figure will help...
Thanks
Minolta DImage 5400 lens - actual resolution?
Have you read this report on the 5400 II ? Almost at the end, under the heading "Picture Quality" they tested with a USAF test chart.
https://www.filmscanner.info/MinoltaDim ... 400II.html
Re: Minolta DImage 5400 lens - actual resolution?
from all the tests around it seems to me that it's comparable to a printing nikkor on small sensors.Beatsy wrote:In all the discussions about the DImage 5400 lens, did we ever determine it's actual resolution subject-side (smallest resolvable distance in microns)?
if we look at page 9 of the printing nikkor 2:1 at coinimaging we get around 3.5um:
http://coinimaging.com/lens_tests_new.html?
and looking at that graph and assuming that one can push it to around 3:1 before empty magnification kicks in, I'd say something between 2.5 and 3um, but probably only at the center.
chris
