Hello
I am looking for a dark-field ring to fit a BX53 with a universal condenser. The official U-UDA is way over priced.
Does anyone know of a suitable alternative?
Many thanks
Paul
Darkfield ring needed
- enricosavazzi
Re: Darkfield ring needed
I am fairly sure I have an extra UDA (genuine Olympus) in my boxes, but it might be difficult for me to find it because I am packing my things and will move about one month from now. I do know I already packed one, but I am sure I have two.Paul Dowrick wrote:Hello
Many thanks
Paul
Just to make sure you know, the UDA can only be used with air universal condensers and objectives, not oil. There is also a limit on the maximum NA of the objective (which I don't remember, but the U-PlanApo 40x 0.85 is most likely not usable because its NA is too high).
For this and higher NA you need to use a dedicated darkfield condenser oiled to the slide (even with air objectives, because the darkfield air condenser does not have a sufficiently high NA to prevent the cone of light from directly hitting the objective front lens).
https://www.ebay.com/itm/264308894870Paul Dowrick wrote:...I am looking for a dark-field ring to fit a BX53 with a universal condenser. The official U-UDA is way over priced.
Does anyone know of a suitable alternative?...
Depends which universal condenser you own ...
Saul wrote:https://www.ebay.com/itm/264308894870Paul Dowrick wrote:...I am looking for a dark-field ring to fit a BX53 with a universal condenser. The official U-UDA is way over priced.
I have the U-UCD8-2
Will not fit. What rings (diameter & thickness) your condenser accepts ?Paul Dowrick wrote:I have the U-UCD8-2Saul wrote:https://www.ebay.com/itm/264308894870Paul Dowrick wrote:...I am looking for a dark-field ring to fit a BX53 with a universal condenser. The official U-UDA is way over priced.
- enricosavazzi
Sorry, all my stuff is now packed away. I did see the second UDA mounted in my spare universal condensor (I use one universal condensor for air DIC, the other for oil so that I just need to swap condensors), but prefer not to disassemble it.Paul Dowrick wrote:That would be amazing if you have. Please do let me know when you get time. And, many thanks for the additional info. It is very much appreciated.
It will be some months before I am in a permanent house and can unpack the unmounted UDA.
There is this guy on ebay selling a variety of condenser inserts in different sizes. I was contemplating of buying a set because i am also looking for an darkfield insert for the UCD8 but have never gotten around to.
https://www.ebay.com/itm/273087400339
Peter
Peter
- enricosavazzi
I bought a similar set a year ago or more, not necessarily from the same seller. The set was supposed to fit into the sleeve around the field lens on the base of the microscope (Olympus BX50) rather than in a condenser. However, at least two of the inserts are too big by a few mm, and a few others just a little too big to fit properly. The set also includes oblique darkfield and a variety of stop shapes.pbraub wrote:There is this guy on ebay selling a variety of condenser inserts in different sizes. I was contemplating of buying a set because i am also looking for an darkfield insert for the UCD8 but have never gotten around to.
Peter
Considering the relatively high price compared to what one actually gets, the lack of dimensional precision makes my set not worth the purchase. With some patience I could have achieved the same result by carefully hand-cutting a black sheet of thin cardboard.
