www.photomacrography.net :: View topic - Some old fiberoptic chips and friends
Bob-O-Rama
PostPosted: Tue Jul 09, 2019 1:20 pm    Post subject: Some old fiberoptic chips and friends Reply with quote
Fiberoptic receiver ( photo diode ) module with optical fiber:
Corresponding fiberoptic transmitter ( laser ) module with optical fiber:
Intact crystal clock chip ( the round clear thing on "springs" is the crystal, its less than 2mm in diameter ):
A different clock module with crystal "removed" it was rectangular and covered up the signal processing chip.
Fiberoptic transmitter module ( identical in function to the first, but newer generation )
PostPosted: Tue Jul 09, 2019 1:50 pm    Post subject: Reply with quote
Bob,
Really nice images.
Where did you get these packages for the fiber optics? Note you are in Allentown, Bell Labs maybe?
~Mike
Bob-O-Rama
PostPosted: Tue Jul 09, 2019 2:04 pm    Post subject: Reply with quote
I do infrastructure and networking, so these are from the scrap yard. If you are accustomed to the usual wafer / integrated circuit shots they tend to be rather 2D. These are interesting in that they are very architectural: stuff piled on stuff. Especially so was the clock chip with all that going on, the entire package is 6mm long.
PostPosted: Tue Jul 09, 2019 2:16 pm    Post subject: Reply with quote
Bob,
Also usually try and create a 3D effect with most of the chips I image, and have a few with QFN packages some larger multi-pin packages. My source has been mostly the chips I've designed or participated in the design, so fairly limited.
The quartz crystal is really interesting, especially the spring type mounting.
I've done a few and for folks that don't want them published, so these I can't show. Some of these are massive Stack and Stitch efforts which has lead me on a Fully Automated S&S System development, after the initial manual efforts Rolling Eyes
Anyway, nice images!! Keep them coming Very Happy
~Mike
Harald
PostPosted: Sun Jul 14, 2019 12:27 pm    Post subject: Reply with quote
Hi Bob-O-Rama,
Great work. Love the two first one. The design of the circuits are just art.
Can I ask you a question?
How do you open them up? Brut force?
Keep em coming!
Thanks for sharing this electronic art Very Happy
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
RDolz
PostPosted: Sun Jul 14, 2019 2:54 pm    Post subject: Reply with quote
Hi Bob:
Excellent images!
Can you tell us the technical aspects: what lens, or combination of them, have you used, .... camera, magnification, etc?
Best
Ramón Dolz
Bob-O-Rama
PostPosted: Mon Jul 15, 2019 12:26 pm    Post subject: The Details . . . Reply with quote
I am on the lookout for ceramic packages which have a top and bottom cemented together, and then use a vice, hammer, rock, etc to violently cleave the top from the bottom revealing the innards. The violence is critical. Without the violence, it just doesn't work. Very Happy Or the packages have a metal lid which is soldered / glued on and you just peel them off. Sometimes they get damaged and the damage is very interesting looking. Mostly its an act of carnage. Its a better fate than the landfill.
The lens is a Infinity Photo-Optical K2 Distamax + CF-3 front lens ( so ~4x with 0.2 NA @ ~100mm wd ) I got for very, very cheap. Its an incredible versatile ( and expensive if paying retail ) system which spans the entire range from astronomy to microscopy. One one extreme, its far field objective does 1:1 to infinity focus with an focal length of about 700mm. It has a range of close focus objective that cover the 1x to 12x range with 60-250mm working distances, and you can attach any microscope objective and use it as a tube lens.
The camera is a Pentax K-1. These were shot with "pixel shift" mode which composites 4 images offset by one pixel to eliminate false color from the CFA, improves the SNR by 2 stops, and most importantly improves the chroma sampling by about 2x linearly. It also uses a fully electronic shutter in this mode ( regular single shot modes only offer EFCS on the K-1 ) so it helps with vibrations. This makes a noticeable difference for sharp lenses.
-- Bob
nanometer
PostPosted: Wed Jul 31, 2019 9:02 am    Post subject: Reply with quote
These are really interesting and well done! I like your instructions for getting them open Smile
