www.photomacrography.net :: View topic - Handheld stacking in Helicon software?
Bcald7
PostPosted: Mon Jun 24, 2019 4:07 am    Post subject: Handheld stacking in Helicon software? Reply with quote
I like using Helicon software. I can't get good results with handheld stacks. Especially when the frames are misaligned quite a bit. Photoshop auto-align works pretty great but I can't figure out how to align them in PS and send the aligned layers to Helicon.
Is there a way to get Helicon to align as well as PS?
Thanks
www.instagram.com/bcald7
Smokedaddy
PostPosted: Mon Jun 24, 2019 9:28 pm    Post subject: Reply with quote
Helicon has a end-user forum.
https://www.heliconsoft.com/focus/help/english/HeliconFocus.html#HF_ADJ
Bcald7
PostPosted: Tue Jun 25, 2019 1:31 pm    Post subject: Reply with quote
OK, sorry. I didn’t realize nobody here used Helicon software.
Smokedaddy
PostPosted: Tue Jun 25, 2019 2:19 pm    Post subject: Reply with quote
No reason to be sorry, lots of people use Helicon here, including me. I was just letting you know they have a forum. I don't know the answer to your question and thought the link might help. I've never done any hand held stacking.
Cheers ...
zed
PostPosted: Tue Jun 25, 2019 3:50 pm    Post subject: Reply with quote
Regardless of the stacking software that you are using - you are likely to get unpredictable results without a tripod or some other stabilization platform. Reliable stacking requires axial stability more than lateral stability - so if your images are shifting right/left/up/down then they are likely shifting unpredictably in the focus dimension as well.
But - to answer your PS question about Layers:
If you use Auto-align in PS to align laterally, you can export these images to individual files using File->Export->Layers to Files. Then you can import these files to Helicon to stack.
https://www.zed.gallery/
Smokedaddy
PostPosted: Tue Jun 25, 2019 4:12 pm    Post subject: Reply with quote
FYI, I have Don Komarechka snowflake book (AKA = donkom here) and he only does hand held macro shooting. His snowflake images are very impressive.
https://skycrystals.ca/product/sky-crystals-unraveling-the-mysteries-of-snowflakes-book/
-JW:
Smokedaddy
PostPosted: Wed Jun 26, 2019 12:55 am    Post subject: Reply with quote
... also IF you use Photoshop, got to Youtube and look up auto align layers. There might be others besides this one.
https://www.youtube.com/watch?v=Y_MAN08qgKk
https://www.youtube.com/watch?v=NOYpq-f0yxg
-JW:
