www.photomacrography.net :: View topic - Automated Stack & Stitch System Robots
Goto page Previous  1, 2, 3
ray_parkhurst
PostPosted: Fri Dec 21, 2018 8:21 pm    Post subject: Reply with quote
Smokedaddy wrote:
As usual I wasn't clear in my question. For example, how do you quantify that you've actually made a 5 micron step on the rail.
Ahh, sorry for misinterpreting...
For full steps, you can pretty much count on the steps being accurate per the calculated values, within the tolerance of the motor specifications.
As long as the system is set up to drive sufficient current through the motor windings, quarter steps will also be fairly accurate.
I think Rik has developed a method for quantifying actual movements, and has published some work on this. Perhaps he'll point us to some older threads where as I remember he quantified the steps of a StackShot.
Smokedaddy
PostPosted: Fri Dec 21, 2018 9:06 pm    Post subject: Reply with quote
Thanks, I was wondering if some sort of mechanical device would be used like a dial indicator. Rik will have some sort of scientific mathematical way of explaining it that I won't understand so I don't want to waste his time.
PostPosted: Fri Dec 21, 2018 10:44 pm    Post subject: Reply with quote
For ballpark $100 you can buy a manual dial indicator with 1 micron tick marks. Substantially more with an electronic interface so you don't have to manually transcribe the measurements.
Or if you already have high mag optics and Zerene Stacker, you can use the substantially more precise method described here:
"Tiny focus steps: how to make them, how to measure them", http://www.photomacrography.net/forum/viewtopic.php?t=11519
Same technique used at http://www.photomacrography.net/forum/viewtopic.php?t=27549 .
The analysis is simpler now, since Zerene Stacker can export the alignment info to a spreadsheet compatible file.
PostPosted: Sat Dec 22, 2018 9:13 am    Post subject: Reply with quote
Rik,
Is this spreadsheet file directly available from Zerene?
~Mike
PostPosted: Sat Dec 22, 2018 10:22 am    Post subject: Reply with quote
Yes, via File > Save Other > Save Registration Parameters. It's a text file with tabs as field separators.
PostPosted: Sat Dec 22, 2018 10:54 am    Post subject: Reply with quote
Great, thanks!!
Rik,
This is a really nice added feature of Zerene! Very Happy
I was able to bring the .txt file into Excel and display various graphs of X, Y, Scale and Rotation parameters! Smile
Here's an example I just got by restacking a section of a Automated XYZ S&S session with Alignments ON.
~Mike
rongyaokou
PostPosted: Mon Mar 23, 2020 12:28 am    Post subject: Reply with quote
These motor is also ok:
https://www.oyostepper.com/category-7-b0-Nema-23-Stepper-Motor.html
https://www.oyostepper.com/category-4-b0-Nema-14-Stepper-Motor.html
https://www.oyostepper.com/category-22-b0-Linear-Stepper-Motor.html
ray_parkhurst
PostPosted: Mon Mar 23, 2020 4:08 am    Post subject: Reply with quote
Be careful when purchasing the round types. Their screw holes are not spaced the same as the square ones and require a custom adapter.
Page 3 of 3
