www.photomacrography.net :: View topic - macro-rail, micro-processor, nano-steps
Goto page Previous  1, 2, 3, 4, 5, 6
PostPosted: Wed May 24, 2017 5:15 am    Post subject: Reply with quote
Adalbert wrote:
Hello Mike,
Have you already measured the size of the wobbles (before and atfer)?
e.g. By the method I tested the backlash (you know with Zerene).
But you should take the photographs along the axis of the movement.
Br, ADi
Adalbert,
No I didn't measure the wobble, but did notice it is definitely periodic. That lead me to believe the wobble is from the rail/stage lateral movement.
My system is completely dismantled now, and probably won't be back to the original setup again anytime soon, I'm working with a different rail system now (THK KR20 type).
That's an easy test for someone to do, since it only requires a few rubber bands and a bolt/screw. I'll have to let others try this out and record the results now. If you look at my post you can see the before and after results.
Adalbert
PostPosted: Wed May 24, 2017 10:20 am    Post subject: Reply with quote
Hello Mike,
OK, and what about the KR20?
A/B, 100/150/200 and your experience.
Br,ADi
PostPosted: Wed May 24, 2017 11:25 am    Post subject: Reply with quote
No feedback on THK KR20 yet. Just completed the mounting onto my baseline setup, so maybe in a few more weeks.
Adalbert
PostPosted: Sat Jan 20, 2018 10:07 am    Post subject: Reply with quote
Hello everybody,
I have noticed recently that the EOS M3 sometimes (up to 5%) cannot be triggered by my IR controller (based on Arduino).
So, I have just connected a "normal" IR remote controller via a relay.
Then I have searched for the reason of the problem with my IR- controller and found out that the duration of the impulse was too long.
So I have changed its value from 9 to 8 micro-seconds and everything is OK now.
Code:
void Camera::doShot(void)
  Serial.println( "impulse-time=" + String(_impulse_time) );
  Serial.println( "signal-time=" + String(_signal_time) );
  pinMode(_pinLedIR, OUTPUT);
  for (int i = 0; i < 16; i++)
    digitalWrite(_pinLedIR, HIGH);
    delayMicroseconds(_impulse_time);       // between 7 and 10 micro-seconds
    digitalWrite(_pinLedIR, LOW);
  delayMicroseconds(_signal_time);        // shut immediately
The program has been changed as follows:
Camera * canon = new Camera (11,8,7300); // pin 11 = IR emitter, pulses = 8 microsec; signal = 7300 microsec
BR, ADi
MacroLab3D
PostPosted: Thu Jan 02, 2020 12:13 pm    Post subject: Reply with quote
Wow... i had the same problem with skipped shots on M3 + UNIVERSAL IR REMOTE from Cognisys. Now after your post (which i found too late) i can assume i should have changed the settings for UNIVERSAL IR REMOTE.
Thanks for the idea!
Update: Just checked settings of UNIVERSAL IR REMOTE and it was set to correct ID1, which is Canon. So... probably problem is still not remote but camera itself?
Adalbert
PostPosted: Thu Jan 02, 2020 1:42 pm    Post subject: Reply with quote
Hello Oleksandr,
I have noticed a common problem with IR but it can be solved by the software.
My rail based on the Arduino generates the IR-signal.
If I assemble a new controller I have to find out the delays for the IR-signal because the internal clocking of Arduino is never the same Sad
So, firstly I look for the best parameters in the loop :-)
And I place the IR-diode close to the camera. See the second picture in the following thread:
https://www.photomacrography.net/forum/viewtopic.php?t=40699&highlight=
BR, ADi
MacroLab3D
PostPosted: Thu Jan 02, 2020 2:36 pm    Post subject: Reply with quote
Funny diode you have there ...
...OMG the image is amazing! The best i have seen!
What i noticed on this forum is that this is a black hole information storage where you can get access only through the DIRECT individual links haha.
You know what? I was thinking to buy Mitutoyo 50X 0.55 but after your shot i am thinking about your Oly NeoSPlan 80x / 0.75.
Mind. Blown.
Adalbert
PostPosted: Sun Jan 05, 2020 6:14 am    Post subject: Reply with quote
Hello Oleksandr,
Olympus NeoSPlan 80x / 0.75 ULWD produces more CA than Mitutoyo M Plan Apo 50x / 0,55 and its WD=4.1mm Sad
BR, ADi
Page 6 of 6
