macro-rail, micro-processor, nano-steps
Hello everybody.
Yesterday I received the LCD-shield and was able to complete my controller.
So, I have added the controller-slat to my macro-slat and have created the Macro-Station :-)
Main features:
1.) Arduino based controller
2.) Open interface programmed easily in C++
3.) Standalone mode and connected to the PC
4.) LCD and 6 keys for the entering of the data
4.1.) Shutter Speed
4.2.) Time for loading of the flashes
4.3.) Aperture for the calculation of the step-size
4.4.) Start point
4.5.) End point
4.6.) Run stack
5.) Connection to the camera remotely by the IR
6.) Size of the steps calculated on the basis of the aperture
7.) Number of the steps calculated on the basis of the distance between the two selectable points ( and step size detected before )
8.) The gear-box 100:1 enables step-size in nano-meters
8.1.) NEMA 17 step angle of 1.8 degree ==> 200 steps for the 360 degrees
8.2.) TB6560 16 micro steps, 1.4 A
8.3.) Gear-box (99 + 1044/2057): 1 ratio
8.4.) Full rotation 318424 (200 * 16 * 99.5075352455031599) micro-steps
8.5.) Mitutoyo screw: scale 25 positions a 0.0254 mm
8.6.) One full rotation ==> movement of the rail = 0,635 mm (25 * 0.0254)
8.7.) Full rotation of the micrometer screw shifts the carriage 635 micro-meters.
At the moment I’m implementing a photo-sensor for the checking if the flashes have fired.
If not then the stacking-session will be stopped.
BR, Adi
Main features:
4.1.) Shutter Speed
4.4.) Start point
4.5.) End point
4.6.) Run stack
BR, Adi
Thanks for the clarification. It will be remarkable if those are actually free of backlash. The unit that I have is spec'd as<=1° . That's for a 14:1 system, where 1° corresponds to about 7 full steps of the 200 steps-per-rotation motor.Adalbert wrote:This planetary gear-box contains very precise gear-wheels as in a Swiss watch
It would be very interesting to see a plot of carriage movement versus motor steps as the rail is first driven forward and then reversed and driven backward. My guess is that backlash would be easily apparent, and much more than you expect. As a matter of practice this doesn't have much effect except for requiring pre-run when setting limits and starting the stack, but I think it's always good to know what the hardware is really doing.So, the backlash is not really measurable.
I usually think of backlash as the space between meshed gear teeth for an individual mesh. A planetary gear drive normally has several gears in mesh, some in series, some in parallel depending on the design. For a planetary gearbox the effective backlash is the sum of the backlash of each mesh with the mesh ratio properly applied. A backlash check of a planetary gear set would be to hold one end fixed (input or output) then to measure the rotation of the opposite end. When the reduction ratio is large the backlash is likely to be larger on the input side than on the output side.
Some backlash is usually desireable in high torque gearboxes to accomidate load deflections or thermal deflections. Backlash also allows interchangeable parts with normal production tolerances. Highly accurate instrumentation gearing that sees light loading can be designed with minimal backlash, and occasionally light interference.
The effective backlash can also be reduced by providing a large bias load (I have seen bungee cords and weights used by others on this forum) so that gear teeth and actuator lead screws are loaded on the same side and do not shift through the backlash.
On my friction belt driven rig I have little backlash, but I have lots of hysteresis. The hysteresis results from the tension needed in the rubber band "belts" to get the pulleys to move. I counter this in my stepper control by deliberately pushing the actuator ~50 steps farther than the starting point then pulling it to the position for the first shot. I then pull it through each successive shot till I reach the hast one. Many stacking rigs do something similar I believe.
You may discover a bit of hysteresis in your rig also. Your build looks very clean and should work well!
Keith
Keith
Agreed. And with the unit that I have in hand, when I clamp the motor+gear assembly and turn the gear output shaft, there is approximately 0.1" of free movement at the end of a 6" lever arm. Unless I've blown the calculation, that amounts to something between 0.9 and 1.0 degrees of rotation, so right on spec.BugEZ wrote:I usually think of backlash as the space between meshed gear teeth for an individual mesh. A planetary gear drive normally has several gears in mesh, some in series, some in parallel depending on the design. For a planetary gearbox the effective backlash is the sum of the backlash of each mesh with the mesh ratio properly applied. A backlash check of a planetary gear set would be to hold one end fixed (input or output) then to measure the rotation of the opposite end.
In Adalbert's system, whatever angular backlash there is in the gearing will be multiplied by the screw pitch. At 0.635 mm per turn (635 micro-meters), 1 degree backlash would be only about 1.7 microns at the screw. On the other end, with 100:1 gearing and 200 steps per rotation, the motor would see something like 55 full steps of dead rotation.
Hello Rik,
According to the description of my gear-box it has a “backlash at no-load <=1 ° ”
Probably it is a property of the motor because you have the same value.
So, I only can observe some backlash during the changing of the direction of the rotation ( I can hear it :-)
If the rail is driven in one direction I cannot notice any backlash ( probably because of the hard-steering micrometer-screw ).
What does “pre-run when setting limits” mean?
I only set the first point then the second point and finally run the stack from the second point to the first point.
BR, Adi
BR, Adi
That's the (undesirable) parameter I was originally thinking of. Perhaps there is a difference in interpretaion of backlash/play/free movement...?I only can observe some backlash during the changing of the direction of the rotation ( I can hear it :-)
I think "the point" is that microscope focus blocks, don't effectively have any backlash. The statement is valid though, when they're pre-tensioned by gravity or a spring. I have a simple adjuster which has about a 3.3:1 planetary gear reduction. With that, tension on the output is maintained through the gears in a way that a spring would hold them all in tension. Perhaps your gearbox is two of those in series?
If you have enough sets in series, eg Here:
https://www.youtube.com/watch?v=MUH0MGP7AGc
then I doubt the tension would be transmitted back to the motor.
Even if there's no gap between the gears, I'd still expect there still to be a measurable elasticity, depending on the force and number of gears, on change of direction.
Hello Keith,
Many thanks for the info!
In my case is very difficult to measure something because of the big translation.
Maybe you can find some information on the following site http://www.omc-stepperonline.com/
BR, Adi
BR, Adi
Hello Chris,
BR, Adi
Yes, for sure but it is too small for me. I don’t have the equipment in order to measure something in NANO-meters“Even if there's no gap between the gears, I'd still expect there still to be a measurable elasticity, depending on the force and number of gears, on change of direction.”
BR, Adi
Hello Chris,
The smallest step of my rail is about 2nm and good enough for me :-)
My current gear-box is 100:1
BTW, for the macro-photography I will use the gear-box 5:1.
BR, Adi
BR, Adi
