Just a quick test.
I took some photos with the Storz. The source was a Vogue magazine, and the subject CZJones not completly B&W, most of the coloured dots are actually in the image. Area of the image being photgraphed in images 1 and 4 is 4x 3cm.
Probably need to look at the bigger versions to really see what's going on. They are about 4-5mb in size.
The first image is the Storz attached to the D100 + PK13+PK12+PK11a at f=140 Just selected a nice composition to start with.
The second shot is the same configeration as above but closer and refocused again at f=140. That's the beauty of this lens, adjust shot and refocus with the lens focusing ring.
The third shot is the Storz attached to the PB6 bellows fully extended f=140
The fourth shot was taken with the D100 and a Carl Zeiss Jenna Sonner 135mm at f11 +PK13+PK12+PK11a just for comparison.
I didn't worry too much about the lighting - it was hand held fiber optic. Have not gone into detail regarding technical specs; just wanted to
initially see if the image degraded outward from the center. Didn't lock down the equipment so the focus could be sharper and the exposure longer.
