Teleconverters in macro
Harald
Re: Teleconverters in macro
Post by Harald »
JKT wrote:
Thu Feb 02, 2023 2:00 pm
On that one you likely wouldn't see the difference as there is nothing near the corners. The rainbow colors you see are not due to the TC.
There is more to the macro/micro world than minerals. I also do some botanical images
Just got an 1.4x III for 200$
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
bralex
Post by bralex »
Harald wrote:
Fri Feb 03, 2023 8:25 am
Blasphemer!
Scarodactyl
Post by Scarodactyl »
bralex wrote:
Sun Feb 05, 2023 10:49 am
Blasphemer!
Let's not be hasty. Maybe he means mineralloids.
JKT wrote:
Wed Jan 25, 2023 1:08 pm
rjlittlefield wrote:
Tue Jan 24, 2023 8:36 pm
That will also be effective f/25 as seen by the sensor. (Feff = m/(2*NA), m=14, NA = 0.28)
...or is it actually f/24? Which is the accurate formula - m/(2*NA) or m*fwork?
Combining the latter with fwork = 1/2/tan(asin(NA)) gives the other value ... but have I gotten that formula right?
Yes I know - practical effect is minimal. :)
Anyway, with that formula the Mit 20 is f/21.6 without TC and f/30.3 with it. What that means in sharpness should be easy to test with any lens that stops that far down.
Sorry, I missed this question earlier.
It is f/25. Both formulas for Feff are correct, but your formula for fwork is not correct. See viewtopic.php?p=196511#p196511 and following.
JKT
Post by JKT »
Sun Feb 05, 2023 5:49 pm
[It is f/25. Both formulas for Feff are correct, but your formula for fwork is not correct. See viewtopic.php?p=196511#p196511 and following.
OK - I had a nagging suspicion I had seen something to that effect. Thanks for settling it!
As a side note, is it really so that the f# reported at Photons to Photons optical test bench is effective f-number, BUT calculated with P=1? That seems to be the only way to make the results work. There was also a small remark in one of the Optics primers that could be interpreted that way. The effect becomes rather drastic when the P drops under 0.1 in the worst case...
JKT wrote:
Sun Feb 05, 2023 11:12 pm
My understanding is that https://www.photonstophotos.net//GeneralTopics/Lenses/OpticalBench/OpticalBench.htm operates by tracing rays and then interpreting their paths to derive f#, NA, and pupil ratio. So the reported f# is automatically the effective f#, as seen by the sensor in the lens's normal orientation. NA is reported for the same place, so it should be that NA = 1/(2*f#), and that has checked OK in all the cases that I have seen. For the OpticalBench simulator all these numbers are outputs, not inputs, and they are all on the image side. The simulator could give corresponding numbers for the object side, and if it did, then I expect that all the numbers on both sides would be consistent with the standard formulas. But it does not, so I do not see any way to check that aspect.
Can you give me a specific example of the situation that you're wrestling with, and a specific pointer to that small remark you mention?
JKT
Post by JKT »
Mon Feb 06, 2023 10:01 am
The worst case I run into was Tamron SP 180mm f/3.5 macro. The table below is copied from the optical bench and the white cells are inputs. WD, H, H', S & L are not relevant here.
The problem is with the higher magnifications. If the effective aperture (for nominal 3.5) was indeed 5.43 at 1:1 as the bench results claim and the pupil magnification 0.08, the required nominal aperture [ f.eff / (1 + m / P ) ] becomes 0.4 and that seems impossible. So there is clearly something wrong and it likely is in my end, but I just can't figure it out.
Forget the part about primer claiming that P would be ignored. That was a misunderstanding. The gray f# number values are based on that, so they are wrong too ... which is too bad as they did behave much more reasonably. :)
JKT wrote:
Mon Feb 06, 2023 1:10 pm
Thanks, I see the issue. It would take me too long to work up a detailed math explanation of what's going on. Conceptually, the key element is that at close focus this lens is working its way toward being telecentric on the object side. That means the entrance pupil is moving far back and getting very large. If you tried to shine parallel rays in the front, you could not come close to filling the pupil. The entire pupil can be seen only by an object that is close to focus. In the lens's working configuration, at close focus, all the angles make sense and it's only these mathematical entities called "pupil magnification factor" and "nominal f-number" that get weird. I expect the standard formulas would still work out OK if you're careful to apply them only to configurations where the entire pupil is in play, and if you're prepared to ignore craziness in the intermediate numbers that eventually disappears in the final result. As a matter of practice that means you could apply the formulas to compute the effect of small deltas like say adding some extension behind the lens that is already in its close-focus configuration, to compute how the f-numbers will change. But computing a nominal f-number, which corresponds to an object at infinity, when only a tiny part of the pupil could be seen from there, will produce an intermediate number that does not correspond to physical reality.
For a lens that is perfectly telecentric on the object side, the entrance pupil is infinitely large and located at infinity, so p=0, and that wreaks total havoc with the standard formulas even though the ray paths don't look strange at all. There are some counterintuitive behaviors such as object-side f# not changing if you focus the lens closer by adding extension. (See viewtopic.php?p=249989#p249989 for some discussion of that.) The formula about f_image = m*f_object still applies, so this means that focusing a telecentric by extension, f_image varies as m instead of (m+1). Surely there must be some way to rewrite the equations so that plugging in p=0 gives that same result, but I've never spent time figuring that out. [Edited to add: That's done now, see viewtopic.php?p=287081#p287081 .]
Question: how did you construct the table? I don't know how to get the photonstophotos OpticalBench to do that.
JKT
Post by JKT »
Mon Feb 06, 2023 3:02 pm
OK - that explains it ... at least enough to tell me not to touch THOSE formulas. So the values are effective and correct after all. Theoretically that should make the lens useful for stacking in some cases, but unfortunately it is not that sharp at 1:1. And Thanks again!
The hard way. :D Copy values, change focus and repeat ... ad nauseam.
JKT wrote:
Mon Feb 06, 2023 3:48 pm
Bummer -- I had hoped to learn some magic!
JKT
Post by JKT »
In case someone is interested here are some polynomial approximations for Pupil magnification, focal length [mm] and effective aperture for macro lenses in Canon world.:
The approximation are actually pretty good - likely much better than required. The only exceptions are the ones noted in the latter picture. At full aperture some lenses develop another stop which drops the effective aperture more than the formula shows. That effect is worst for the EF 100mm.
The lenses are:
Canon EF 180mm f/3.5 L macro
Canon EF 100mm f/2.8 L macro
Canon MP-E65 f/2.8
Canon EF-S 60mm f/2.8 macro
Canon EF-S 35mm f/2.8 macro
Online
enricosavazzi
Post by enricosavazzi »
The OP asked about teleconverters in macro on a Canon camera. For other members using Micro 4/3, my tests with the Olympus MC-20 2x teleconverter may be relevant: https://www.savazzi.net/photography/olymc-20-macro.html
Guppy
Post by Guppy »
Hi
The MITUTOYO M Plan Apo 10X/0.28 ∞/0 f=200 on a Nikon D810 pixelpitch 4.9µm resolves the object with 950LP/mm.
The MITUTOYO M Plan Apo 10X/0.28 ∞/0 f=200 on a camera with pixel pitch 2.2µm resolves the object with 950LP/mm.
The MITUTOYO M Plan Apo 10X/0.28 ∞/0 f=200 on a Nikon D810 pixelpitch 4.9µm with teleconverter 1.4x, resolves the object with 950LP/mm.
The MITUTOYO M Plan Apo 10X/0.28 ∞/0 f=200 on a camera with pixelpitch 2.2µm with teleconverter 1.4x, resolves the object with 950LP/mm.
The MITUTOYO M Plan Apo 20X/0.42 ∞/0 f=200 on a Nikon D810 pixelpitch 4.9µm resolves the object with 1400LP/mm.
The MITUTOYO M Plan Apo 20X/0.42 ∞/0 f=200 on a camera with pixel pitch 2.2µm resolves the object with 1400LP/mm.
The MITUTOYO M Plan Apo 20X/0.42 ∞/0 f=200 on a Nikon D810 pixelpitch 4.9µm with teleconverter 1.4x, resolves the object with 1400LP/mm.
The MITUTOYO M Plan Apo 20X/0.42 ∞/0 f=200 on a camera with pixelpitch 2.2µm with teleconverter 1.4x, resolves the object with 1400LP/mm.
With teleconverter the resolution of the object is not higher (empty magnification).
Kurt
Kurt, I think this is not necessarily true, though maybe your numbers could be close to correct for the particular combinations you gave. Unlike digital zooming (which does just give empty magnification), increasing the magnification with a teleconverter can increase the actual resolution on the subject, if the aerial image of the original lens out-resolves the sensor.
bbobby
Post by bbobby »
Guppy wrote:
Thu Feb 16, 2023 8:53 am
Kurt
You may be right that there is empty magnification in this case, but maybe the reason for that is not that TC is not doing the job, but probably because of the diffraction limit there is nothing to magnify ;-)
My math could be wrong, but 10X/0.28 is effective aperture of 17.9 and even worse for 20X/0.42 - 23.8. For 2.2µm sensor you will need something like 10/0.70 so the teleconverter will have something to magnify...
