https://es.aliexpress.com/item/10050035 ... pt=glo2esp
Salut
An excellent tool to make yourself Rheinberg filters
Re: An excellent tool to make yourself Rheinberg filters
oh my gosh, finally I can cut round aperture stops!
- blekenbleu
This seemingly similar ANSAI Circular Cutter (1mm-50mm) should also work, based on its video:
https://www.amazon.com/vdp/0c355169e1e0 ... 70fc6f3ec6
... and is available with shorter lead time in the U.S.:
https://www.amazon.com/dp/B09N3Q94Z5
I was concerned that the ANSAI cutter explicitly says "thickness less than 0.4mm".
However, clipping an image of Chinese text from the picture of the USTAR package, and translating that to English by running it through https://translate.yandex.com/ocr , produced the spec "Suitable for cutting 0.3 mm one rubber sheet, cover tape, ..."
So, it seems that both devices can handle only thin material, with the ANSAI spec'd for slightly thicker.
I've had two of these in my drawer for 30 years. Cut perfect circles, but below 15-20mm you may have to repeat the attempt several times
- blekenbleu
On receipt, I was pleased to discover that the blade carrier assemblyblekenbleu wrote: ↑Sun Sep 11, 2022 9:52 amANSAI Circular Cutter (1mm-50mm)
rotates in a 65mm i.d. 6813Z sealed roller bearing, which by itself often lists for more than the entire cutter.
Replacement blades are also available on Amazon
https://www.amazon.com/dp/B0B9FTSXGW
Blades are available in 3 cutting angles for different cutting depths:
https://www.ebay.com/itm/354243566884
As received, the 45-degree cutting tip is inside a yellow soft polymer cover.
Mine included a spare tensioning spring.
My wife is into scrap booking ( in fact at a huge scrap booking convention this weekend ) - she probabaly has 7 different ways to make this already. LOL!
