ImageMagick difference image generation hack
blekenbleu
Post by blekenbleu »
ImageMagick is IMO powerful and useful, but not always easy for me, despite being moderately comfortable with a terminal command line.
This is a hack to display pixel-by-pixel differences between 2 images, typically registered.
ImageMagick offers an example image differencing invocation:
Code: Select all
...but
  • small differences are nearly black, displaying poorly
  • differences are also absolute; gray - blue == blue - gray
https://imagemagick.org/Usage/compare/#difference
This invocation results in middle gray for no difference, with gray - blue = yellow:
Code: Select all
magick CZP_Helicon_Comparison_H.jpg.crdownload CZP_Helicon_Comparison_C.jpg.crdownload -compose Mathematics -define compose:args="0,-1,1,.5" -composite ugoo.jpg
.. where those first two images are from https://www.photomacrography.net/forum/ ... 643#p37643
and resulting ugoo.jpg is this:
Documentation for ImageMagick Composition Mathematics:
https://imagemagick.org/Usage/compose/#mathematics
Pretending neither to type reliably nor remember that syntax,
I hacked an dimg shell script that expects 3 filenames
and created an alias for invoking it.
https://blekenbleu.github.io/ImageProcessing/dimg.html
A next step involves hacking a utility to register image pairs,
given images of mismatched magnifications and/or orientations.
MarkSturtevant
Re: ImageMagick difference image generation hack
Post by MarkSturtevant »
The image looks a lot like a Nomarski DIC picture. Interesting.
Mark Sturtevant
Dept. of Still Waters
blekenbleu
MarkSturtevant wrote:
Tue Aug 16, 2022 4:34 pm
Now that you mention it, comparing images that differ mostly in how sharpened, then mostly edges differ.
Here is a difference image from @RobertOToole's M-Componon 4/28 vs Componon 4/28 corner crop pair:
https://www.photomacrography.net/forum/ ... 25&t=38831
These were first aligned using Hugin's utility:
Code: Select all
magick al0000.tif al0001.tif -compose Mathematics -define compose:args="0,-1,1,.5" -composite diff.jpg
... where left.jpg and right.jpg had first to be cropped to exactly the same pixel dimensions.
Whatever warping was done by align_image_stack presumably compromised both similarly...
Here is difference for unaligned images:
