Test, using Teleconverters and/or extension tubes on a microscope (I found what was wrong)
Re: Test, using Teleconverters and/or extension tubes on a microscope
The pictures of your set-up show ytubes that seem far too short, but I think I may still be misunderstanding it. My teleconverters all maintain focus exactly when inserted into the optical chain.
seta666
Re: Test, using Teleconverters and/or extension tubes on a microscope (found the error)
Post by seta666 »
I found what was wrong with this set up, I was not taking into account the differences in flange distance of Nikon vs NEX (46.5 vs 18mm) which is like adding extension.
I made a drawing of what it would be to focus a hypothetical 100mm tube lens, first without teleconverter and then with teleconverter showing what was wrong with my set up and how it should be done.
Good news I can fix it in my vertical set up, bad news is I can not use it on my scope; my phototube is now 11mm long and still 1mm off; TC should be placed inside the trinocular head.
The only native sony FE 1.4x teleconverter is 500€, not worth it without testing it first.
PeteM
Re: Test, using Teleconverters and/or extension tubes on a microscope (I found what was wrong)
Post by PeteM »
I'm coming to this a year late, but do have a possible work-around to put a teleconverter "inside" a Nikon finite trinocular head. Use a Nikon teaching head as a 50-50 trinocular head. You'll have 1.25x magnification and need only a Nikon dovetail mated to Nikon bayonet mount -- and then to the teleconverter. One could also remove the head and fit this directly to the top of the stand for 100% light to the sensor.
