Hi, i shoot inclusions in amber and for versatility purpose, i rather install specimens between 2 microscope specimen holders (glass slices) covered with gel in order to "flaten" the field of view, than emerged on a liquid. This mainly to preserve the ability to position the specimen more freely (if the word make sense, English is not my native language).
In the past i'ved tried many kind of gels (echography, lubricantes...) and found a lubricante which gave me pretty satisfactory results.
As i always try to improve my setup, i'm looking for a gel (not too liquid) with a refractive index as close as possible as the amber (+/-1.54)
Thanks in advance
Gel with specific refractive index
Re: Gel with specific refractive index
The last one i use who doesn't work because on high magnification it shows a kind of granulometric texture and a light blue color was "Ultrasound Gel by Liquasonic". However, the consistency was great as it doesn't spills from the specimen holder "sandwich".
The one i am using for quite a while now is "Gel Lubricante" made by Calox. My supplier don't really trust i use such quantity for photography....LOL
This one is ok, it doesn't display any side effect (or i can't attribute them directly to it...) but it tents to spills from the specimen holders when used with thick amber pieces, he's very ok for thin ones.
Still looking for the Holy Grail...
Any use?
https://www.cargille.com/about-optical-gels/
Sub-Lux nD 1.54 Code 081160C
Cat #: 24330
Code: 081160C
(M)SDS
1 fl.oz (30 mL)
4 fl.oz (120 mL)
$104.25
Cat #: 24330
Code: 081160C
(M)SDS
1 fl.oz (30 mL)
4 fl.oz (120 mL)
$104.25
forgot to mention that as will be in contact with amber......can't contain any harsh chemical.....
Need to check out MSDS of candidate gels like above suggestion?
there are silicone products used for LED manufacturing with high refractive index
http://www.siliconeoil.net/product-high ... a4022.html
https://www.wacker.com/h/medias/7308-EN.pdf
Thanks all for your interest on the matter.
I will investigate deeper on the mentioned links you guys provide
