A question for fluorescence microscopists
I was wondering, do those of you doing fluorescence microscopy use quartz or fused silica microscope slides and coverslips, or do you just use normal glass ones?
Jonathan Crowther
Re: A question for fluorecence microscopists
You only need quartz slides and covers if you use short UV radiation.
Fluorescence excitation microscopy is mostly done with blue, violet and long UV (360nm to 400nm) light and most glass slides and covers are adequate (some ones can show excessive autofluorescence, particularly oldest and bad quality ones).
Re: A question for fluorescence microscopists
Ok thanks Pau. Yes, I was wondering whether autofluorescence would be a problem even with longer wavelength UV. Are then any hints for buying glass slides with low fluorescence?
Jonathan Crowther
In slides, autofluorescence is associated with iron content. The best slides have low iron content and are marginally more expensive because they rely on low iron content raw materials.
I would recommend just going for quality slides - from Menzel or Marienfeld. They also make cover glasses from low autofluorescence Schott D 263 M. It's a shame they are a bit expensive for end users, because when bought in bulk they are very affordable.
Cover glasses are probably more important than the slides as they are closer to the object and the high intensity illumination cone.
That's good to know Ichthy. My glass ones are basic cheap ones, and that probably explains why they light up under UV.
I see Thorlabs do the D263M coverslips, and in bulk quantities if needed.
Jonathan Crowther
Posting this in case it is of interest to anyone. I've done a little bit of work on glass and quartz / UV fused silica slides and coverslips, looking at UV transmission and fluorescence with different UV wavelengths.
https://jmcscientificconsulting.com/uv- ... overslips/
Mods - I hope this is Ok to post, please let me know if not.
Jonathan Crowther
No problem Rik, glad you liked it. The idea with those updates is to share as much as I can of my experiences while I learn about making a UV microscope.
Jonathan Crowther
Excellent, this is great information, thanks! I had seen blanket recommendations that a normal thin glass coverslip does not block UV light, but your thoroughness reveals that this (and fluorescence too) changes dramatically with just a small change in excitation wavelength. Very nice thougthtful demonstration.
You're welcome, happy to share results like this as and when I have them.
Jonathan Crowther
Nice post! The transmission results line up well with the published data https://www.schott.com/en-gb/products/d ... al-details
