Lou, the Ultrafluar is fully collor corrected from about 200nm to 1100nm (see link). The UV Mikrotar seems to be just a quartz lens. The reflective lenses mentioned (Edmund Optics) are also fully color corrected.Lou Jost wrote:Klaus, thanks, I know the Ultrafluar is good, but very expensive. Are the other ones you mentioned really good? For both visible and UV light, or just UV? I would like to use through-the-objective UV lighting to excite fluorescence.
And why do so many UV objectives require a coverslip? Doesn't a coverslip reduce transmission? Or is it so thin that it doesn't matter?
I forgot to mention the various LOMO UV lenses, quite cheap to find.
If you want to do high quality UVIVF then the Zeiss Fluar lenses should work well, as they were designed for that once and allow enough UV light to pass, see here:
https://www.micro-shop.zeiss.com/en/us/ ... ar-5x-0.25
Older, finite low power (low magnification) Fluar objective can be had used for just around $150. Modern infinity ones are $$$$
