Interesting stuff
This area is for the discussion of what's new, what's on your mind, and general photographic topics. A place to meet, make comments on this site, and get the latest community news.
ray_parkhurst
Re: Interesting stuff
Post by ray_parkhurst »
lothman wrote:
Mon Dec 14, 2020 1:41 pm
ray_parkhurst wrote:
Mon Dec 14, 2020 11:54 am
Indeed I am still puzzled by these wires. For now they will remain a mystery.
hardened and then blued steel, I'm rather sure it was made for replacing worn pivots, but I wonder of the fine steps in size and the large quantity. That's enough for 10 watchmaker careers.
https://www.youtube.com/watch?v=9p6yjtDA99E
Indeed, this must be the case. In fact I used your key word "pivot" in a web search and it came up with some good hits:
https://milehiclocksupplies.com/catalog ... evised.pdf
https://www.cousinsuk.com/product/pivot ... el-by-size
I think this is the answer, though these go smaller than what I see in these refs.
I've been offline a while, and missed this. My uncle was a watchmaker, his workroom had a lifetime's collection of materials like Ray's. He used his "set of turns", which I think he'd made himself, rather than a full lathe. I made a couple of replacement pinions and bushed a couple of tiny watch plates as a challenge. If the hole in the plate has worn elliptically or off-centre, it's tricky to drill for a bush as you have to work out and hold the centre you want.
This bush supplier lists them with pivot diameters down to 0.1mm.
https://www.hswalsh.com/sites/default/f ... System.pdf
I also tried to cut the teeth for a cannon pinion (the gear which drives the hands) - and messed it up completely.
One of those trade/crafts which is almost extinct. HIs storage system seemed to revolve around "baccy tins", another endangered species.
ray_parkhurst
ChrisR wrote:
Thu Dec 17, 2020 3:01 pm
Thanks for the further info Chris. It seems the mystery is solved. Now I need to figure out what to do with 10lbs of pivot materials...
lothman
Post by lothman »
Thu Dec 17, 2020 4:39 pm
sort them in small sets and sell them on ebay :-) if you could find a convenient plastic box or zip bag which could be labled with the wire size this could work.
Such work can only be done in Covid Lockdown :lol:
tubes
https://www.aliexpress.com/item/3298176 ... hweb201603_
