wasp eye at 10X
wasp eye at 10X
Ichneumonid (I think) wasp, found nearly died in my bathroom
This is a test shot whith a nikon CF Plan 10X infinity microscope objective, focused whith a tele lens Olympus 200mm f4. Canon 20D
(see http://www.photomacrography.net/forum/v ... sc&start=0 for details about this kind of setup)
Stack of 90 images whith Zerene PMax
50% crop to see resolution
100% crop of a single frame. The longitudinal crhomatic aberration is very high
My findings:
- resolution, working distance and easy to use are very good
- Lateral CA is present, but only in the borders (not visible in this images)
- Longitudinal CA is very high :shock:
- Zerene Pmax did an admirable job, not only giving a near artifact free image but also removing efectively almost all longitudinal CA :D
Rick, please move it to Equipement discussions if adequate.
Any comments and advice wellcome
Thunder
Post by Thunder »
Very nice, that last one would make a nice poster.
morfa
Post by morfa »
Great to see more images with this approach so thanks for posting Pau! I like the dreamy feel in the first image – nicely chosen depth of the stack with an unusually pleasant transition from sharp to blurry!
I have to confess that when I saw the last image I just thought "ouch, that's a lot of LoCA" but reading Thunder's comment made me reconsider and agree – it's really quite beautiful! Good to have an art major on the board! :)
ChrisLilley
Re: wasp eye at 10X
Post by ChrisLilley »
Pau wrote: - Longitudinal CA is very high :shock:
Longitudinal/axial CA is indeed very high and the secondary spectrum is the classic magenta in front / emerald green behind of an achromatic lens.
I guess the objective does not claim to be apochromatic (and not all lenses which do claim it are, in fact, apochromatic).
Since axial CA is an artifact of OOF areas, I guess it should not be too surprising that stacking removes it (but the extent to which it does so was indeed a surprise, to me at least).
Joaquim F.
Post by Joaquim F. »
An excellent first contact!
It's the same lens that I'm using, some specs here:
http://www.capraoptical.com/products/ni ... cfepi.html
In the Nikkor 200 / 4 AI are also those magenta-green CAs , but that objective have that tendency in normal photography too, the Olympus behaves similarly?
Try close the Olympus to f/5.6, even at f/8 if the distance between the optics is very short, in my setup seems to decrease in some degree the CAs and general "flare" too.
I fully agree with your analysis.
Best regards (saludos)
Joaquim
Thanks all for your comments.
Good point!, but it's already at 100%, it will be a very little one :)
I agree, it's a plan achromat, but the amount of LoCA is the higher I never see. Other stacking aproaches, like Zerene DMap or Combine ZP did not remove it at the same extent.
I will try it later, and also whith my zoom as tube lens (70-200 f4L usm IS), Rick has tried it with a cheaper one whith excellent results.
