house fly portrait
nto
house fly portrait
Post by nto »
tried again with sigma 105 and reversed 50 nikon, with light not very satisfied, board eye and colored backgrond reflection :D
Technical info:
350d
extension tube 25mm
105mm set to f/6.3 at 1:1
nikon 50mm set to f/4 at infinity
two flash wtih diffuser
additional diffuser for subject
23 frame step 0.1mm
aligned with CombineZM, stacked with Tufuse
Image side crop
edit: caption Sarcophagidae portrait to house fly portrait
ciao
Antonio
lauriek
Post by lauriek »
Really nice! Not sure about the pink, I guess that's the background you're talking about?
Lovely stack though, cannot see any problems! ;)
I like the glow on the mouth hairs, and the dof falloff in the hair around the face is nicely done..
nto
Post by nto »
clarification: fly larger than the usual house fly
Thanks Laurie, yes is pink , color samples are used by painters house walls
light problem can not clone your light and very difficult :D
Antonio
Post by Planapo »
This looks great, Antonio! The only thing I could think of for slight improvement is that lighting on the fly´s right eye (i. e. the left-hand one from the beholder´s point of view) I somehow like better than lighting on the other eye. It seems that the light on the fly´s left eye was a bit less diffused or hit from a different angle and thus is a little harsher. But this is only my personal opinion. Nonetheless it´s an excellent photograph that has this SEM-like appearance which I like. =D> :D
One question concerning your set-up which obviously works so well: You wrote that you used a 50 mm Nikon at infinity, hence I guess it was not the EL-Nikkor that you reverse mounted onto your 105 mm macro lens? But could one use the 50/f2.8 EL-Nikkor instead or should one better use a standard 50 mm taking lens for this purpose?
--Betty
nto
Post by nto »
Thanks Betty,
yes light not aligned well, for right eye, small portion diffuser flash external diffuser subject (I dare not think difficulties with 10x and positioning light :cry: ) :D
50mm is AF Nikkor 50mm f/1.8D
with nikon el 50 f/2.8 not tried, but I think it is best traditional 50mm at f/4
with sigma, front lens and distant of 32mm by filters ring,
maximum magnification possible and 3x,
50m at f/5.6 improves very quality, but with 25mm extension tube sticker board, optimum quality found with 105mm at f/6.3 and 50mm at f/4
with other setup 100mm and 50mm not know maximum magnification possible and optimum quality
sorry for language incorrectly
edit: 3.2mm by filters ring to 32mm by filters ring
Antonio
dmillard
Post by dmillard »
Excellent detail and definition!
Post by Cyclops »
Excellent portrait,bravo! I envy you guys when you can get photos well this good!
nto
Post by nto »
Many Thanks Guys :D
Antonio
