The Zinnia flower made a nice subject to photograph.
Zinnia
Re: Zinnia
Nice! Especially the second one.
Care to describe how you did the photos? Equipment? Stacking?
Re: Zinnia
Hi Klevin, thanks for the comments. Camera body is a Canon EOS 1DMIV. I shot these at ISO 100 using a Canon EF100mm f2.8 macro with extension tubes and the close up with the Canon EF MP-e65. Lighting used was a Canon macro twin lite mt-24ex, with the light diffusers wrapped with Polyethylene EPE Foam Sheets (packing sheets). I also use circular polarizing filters on the lenses. I put some reflective material around the base to help with the lighting. All shots were taken using a focusing rail to stack focus. I am incrementing focus by hand but have the camera setup with continous mirror-up and a 10 second timer between shots to help with vibration. Im shooting the images in RAW and (now) saving in TIFF format 16bit (after reading a few articles by Rik and C. Krebs (very helpful). I used Zerene Stacker and Photoshop 6 to process the images. That’s pretty much it.
Thanks again
Thanks again
Re: Zinnia
Does the Canon EOS utility work with your model? Back when I had a Canon 70D, I used it to manually do stacks in a controlled fashion. Later I moved to an app which automated the process but that was a few years ago, and on a previous computer. I had good results using internal focusing of the 100mm L macro, even with extension tubes. I now use a Canon M6ii, which automates the stacking process. Well worth the investment, IMHO, and works well with the 100L macro via an adapter.
Re: Zinnia
The M6ii sounds like a nice camera. Something that I’ll have to consider more. The 1dm1v doesn’t have an internal stacking process nor does it work with the apps like magic lantern. I do have a Camranger on the want list tho.
- MarkSturtevant
