I would like to share with you a detail of a coffee bean. The main challenge here was composition and lighting, since I wanted to highlight the "groove" in the bean. Lighting was done by a Godox V1 with a small teflon sheet as diffuser and a DIY fiber optic setup powered by a Godox AD200, the diffuser was positioned towards the top-right and the two fiber optic ends from above and from the front right. I hope my explanation makes sense and you enjoy the image.
coffee by Michael Gerlach, on Flickr
technical details:
Nikon Z6II
Godox Flash system (V1 + AD200)
M42 bellows
Makro-Symmar 5.6/120 tube lens, slightly further extended than 120mm
Schneider Xenoplan 1.4/17 relay lens at f/2.8 (~eff. aperture about f/20)
213 frames in 10μm steps
stacked in Helicon Focus (mode B, radius: 1, smoothing: 1)
coffee
Re: coffee
First off, I like coffee, and like this. It shows the unexpected cellular / foamy / bready texture of the bean. If you think the highlights are still bothersome you can try a larger more distant diffuser illuminated by a point source.
I ended up using the plastic diffuser sheets from a scrap LCD monitor - they work great and you get several of them with various "tooth" to them you can arrange in various ways. They are sort of miraculous, having tried a lot of other materials.
Re: coffee
Coffee and macro, two great subjects. Brilliant shot!
