Edited to fix the incorrect moth identification. Thanks to NikonUser for the correct information.
I usually do not photograph too many insects, but seeing as so many here do, I figured id make my first real posting one of a moth. Ill leave the identification to some of y'all who are more knowledgeable. The white spots on the leg and eye are from some high build pre-cat lacquer. Given the little critter had a field day in some paint fumes, I dont know if the loss of scales on the snout are from me or something that is naturally occurring.
All photos were shot on a Nikon D3300 at 2.75x magnification with 1/200 shutter using:
Reversed Micro-Nikkor 55mm f/2.8 @ f/4
Singular Godox Speedlight @ 1/64 power
Dolan-Jenner fiber optic light as fill light
Newport XMS50-S linear stage
190 image stack
190 image stack
cropped section from an 85 image stack
Twirler Moth - Gelechiidae
Re: Crambid Snout Moth
Title misleading. Not a Crambid.
Snout moths are named for their forward-pointing palps that look like a snout!
The palps on your moth curve backwards over the head as seen in many Twirler Moths Family: Gelechiidae.
Here is a snout moth; long palps, snout, in front of eyes
NU.
student of entomology
Oliver Wendell Holmes, Sr
J_Rogers, welcome to posting!
Sometimes it's challenging to figure out what and how will appeal to a new group.
In general, the crowd here at photomacrography.net tends to be sort of "sticklish" about accuracy. Fortunately it is occasionally tolerant of words that sound perfect for the task even though they're not found in any standard dictionary. But I digress...
You've probably also noted that the membership is pretty well stocked with experts in various fields. I'm the fellow who wrote Zerene Stacker, NikonUser does certain groups of insects, and so on. Once upon a time I posted an image of some clock repair parts, and within hours a fellow in Australia told me exactly what they were, including the part number of the kit that contained them. Then there was the wasp antenna with a strange tip, which some fellow in Europe identified to subfamily and gender before even seeing the overview shot. I could go on, but again I digress.
I notice from your profile that you're interested in "subjects ranging from turf grass to tribology & metrology." I don't recall that we have any experts in turf grass, though there could well be one who just hasn't popped up yet.
In any case I'm interested in all that stuff too, so keep the photos coming.
Re: Twirler Moth - Gelechiidae
J_Rogers, I am curious about the stacking for these images.
You mention f/4 at 2.75X. For that setup the standard formula for diffraction-limited DOF gives 0.065 mm.
But then you mention 190 images per stack. If I were to casually multiply 190 by say 0.050 mm, then I get a total stack depth around 10 mm. That seems like more total depth than I'm seeing in these images, so I'm wondering if you used a smaller step size or I'm just guessing wrong about the depth I see.
What can you tell me?
