Firebug nymph at 10, Nikon Microphot/10x MPlan, 191 photos, PMax, Sony A6300
How to keep distance between left & right images in the StereoPhotoMaker ?
Within software is OK, after saving, gap disappears
Firebug nymph
Firebug nymph
Saul
μ-stuff
μ-stuff
Re: Firebug nymph
Stereo as shown looks good. I see a couple of minor artifacts, but the layout and separation are good.
I don't understand your question about StereoPhotoMaker. Can you describe the problem in more detail?
Re: Firebug nymph
Thanks Rik !rjlittlefield wrote: ↑Tue Jun 01, 2021 2:34 pmStereo as shown looks good. I see a couple of minor artifacts, but the layout and separation are good.
Red arrows - is there some way to adjust this separation between L/R photos ?
After exporting to the final image it disappears
Saul
μ-stuff
μ-stuff
Re: Firebug nymph
That separation is only part of the StereoPhoto Maker window. If you change the window size, the gap will change. If you zoom in so that only part of each image appears, the gap will shrink to a narrow black bar. Whatever it is on screen, this gap always disappears when SPM saves images.
Do you want to change the separation so as to move the images forward or backward with respect to the frame? The way I do that is to simultaneously adjust the zoom, SPM window size, and use the left/right arrow keys to get exactly the alignment I want, then I use the crop tool to preserve exactly the parts that I see. File > Save Stereo Image then gives me a single pair with no gap and no frame, or File > Save Left/Right Images gives me two files, each with no frame. Then I use Photoshop to add whatever frame I want.
I do not know how to make StereoPhoto Maker save a file with the frame already added. Maybe new versions of SPM can do that, but if so I never learned the trick. (I do know about File > Print Stereo Card, but I can't figure out how to make it give me exactly what I want.)
Does any of this help?
Re: Firebug nymph
It looks amazing, what a great job!!
Re: Firebug nymph
Thanks Rik !rjlittlefield wrote: ↑Tue Jun 01, 2021 3:18 pmThat separation is only part of the StereoPhoto Maker window. If you change the window size, the gap will change. If you zoom in so that only part of each image appears, the gap will shrink to a narrow black bar. Whatever it is on screen, this gap always disappears when SPM saves images.
Looks like I found a workaround ...
View->Border Options
It does not allow go above 100, but it is enough (at least for me)
Image after saving:
Saul
μ-stuff
μ-stuff
