Sunset moth scales @29X
Macrero
Post by Macrero »
X-T3 + Oly 50/0.80 + Omegaron 105 @29X.
Done in the morning, with cars, buses and miscellaneous vehicles... passing about 5-6 meters from the setup. Didn't come out that bad though.
Higher res: https://images2.imgbox.com/79/d8/yvez8TDG_o.jpg
- Macrero
Guppy
Re: Sunset moth scales @29X
Post by Guppy »
Hi Macrero
Very nice, high res image is excellent.
Do you use flash?
Kurt
Macrero
Post by Macrero »
Hi Kurt,
thank you! No, I've never used flash(es) for stacking. I've often been tempted to set up a flash-lighting setup for high-mag work, but I find continuous light much easier and more convenient to work with. I am a KISS guy :P I like to keep everything as simple as possible...
- Macrero
Guppy
Post by Guppy »
simple is simply good with you
zed
Post by zed »
Very nicely lit image!
I am always curious about people's lighting setups when using an objective with such a short working distance. Care to share your setup for this image?
Cheers!
Adalbert
Post by Adalbert »
Hello Macrero,
well done! :smt041
I think this lens performs better at 100m than at 200mm.
Best, ADi
Macrero
Post by Macrero »
zed wrote:
Fri Apr 09, 2021 7:16 am
Cheers!
Thak you, Zed,
short WD is not big of a problem with bullet-shaped objectives with tiny front elements, as high-res objectives tends to be. Also, I have modded the Oly, I sawed (literally) the front part of the barrel in order to get wider illumination angle.
Here is the lighting setup I'm using:
- Macrero
Macrero
Post by Macrero »
Adalbert wrote:
Fri Apr 09, 2021 9:08 am
Hello Macrero,
well done! :smt041
Best, ADi
Hi Adi,
thank you!
Yep, on MFT and APS I rather use it with short tube lenses.
- Macrero
zed
Post by zed »
Macrero wrote:
Fri Apr 09, 2021 9:19 am
OK - wait - you SAWED your objective? And it still functions?!? Holy cow - do you have a picture of that?
Macrero
Post by Macrero »
zed wrote:
Fri Apr 09, 2021 11:20 am
I sawed the barrel/housing, not the optics :D Mine is the BD version.
A postoperative image :mrgreen:
zed
Post by zed »
That is a very brave (and cool) modification!
I have the non-BD version of this lens and it is almost impossible to get diffused reflected light to the sample unless it is perfectly flat. I have mostly given up on this lens in favor of a Nikon 60x/0.7 finite objective because of this.
Macrero
Post by Macrero »
zed wrote:
Fri Apr 09, 2021 12:37 pm
I bought the objective with the clear intention of modding it. The mod was far from complicated and the result is certainly worth it. But hey, even if it had failed, it's just money, it comes and goes...
The non-BD version is not that suitable for use on camera, given the front part design.
dmillard
Post by dmillard »
Hello Macrero,
I just came across this post from the (relatively recent) past. I have great respect for your courage and skill in modifying the objective to achieve such a beautiful result! :)
Best regards,
David
Macrero
Post by Macrero »
dmillard wrote:
Fri Oct 08, 2021 8:33 am
Hello Macrero,
Best regards,
David
Hi David,
thank you! Glad you like the result.
I like playing high-mag when I have no "models" for lower magnifications. It's really not my cup of tea though.
The mod was easy peasy. Truth be told, it does not really takes that much of courage and skills, but thank you :P
- Macrero
