Microscope M6C-10 camera ZWO ASI071, stack 900 pictures
Pls loom af full resolution: https://www.flickr.com/photos/162118128 ... en-public/
Motor drive on focus
Anyone has a idea how to avoid reflections of the Led ring?
Nice stone
Re: Nice stone
Cross polarization, but this will eliminate ALL the surface reflections. That will definitely change the character of this nice image.Anyone has a idea how to avoid reflections of the Led ring?
Re: Nice stone
I had a good tip from Toni,
The exposure time is doubled and no reflections.
Regards Hugo
i put a white plastic plate with a small hole at 50% of distance (in the middle) between lens and object.The exposure time is doubled and no reflections.
Regards Hugo
Re: Nice stone
Actually there are reflections, but they are more diffused. Cross polarization would eliminate all of them. Your result is a nice balance, not quite eliminating them. Reflections give information about shapes.
Re: Nice stone
The color balance and contrast of the second image are much different from the first.
The second image looks very dark and washed out.
If your camera provides manual control over exposure and color balance, then I suggest to set those from a gray card at the subject's position, with the plastic plate in place the same as it will be for the real exposure.
Also, a question: what causes the irregular black bars on left and right sides of the image?
Re: Nice stone
The black bars are stack problems, I use Autostakkert
