Photo of Ploum
ploum
Post by ploum »
300 photo with ZS. I have tested several software. It's the best for me (neutral image)
I work with a manfrotto 454 but uncommon system :).
Objectives : BW APO PLAN 5x, Mitutoyo APO PLAN 7.5x, 10x, 20x and 50x, Seiwa APO PLAN 20x, BW APO PLAN 20x, Seiwa APO PLAN 10x, Nikon CF PLAN 50x, componon APO 40 mm, Componon 50 mm, Componon S 80 mm, Componon 105 mm, Componon 150 mm, Rodagon 135 mm.....
ploum
Post by ploum »
g4lab
Post by g4lab »
Very pleasant to look at!
Saul
Post by Saul »
Impressive photos ! What is your opinion about Componon S80mm ?
ploum
Post by ploum »
componon S 80 mm is very pleasant for me..... Good working distance i use this between a 2x and a 4x :).
ploum
Post by ploum »
last photo....
Lothar-Gutjahr
Post by Lothar-Gutjahr »
Hi Ploum,
folloing your setup or idea, i modified my so called Ufomi to carry a total length of 70 cm tubing and bellows as a foto unit and tryed Nikor 50 reverse. To get less Magnification i used for the first time my Zeiss Luminar 100. Both lenses show a good behavior and i will try to find a little time to do some experimenting. now i must modify the config of the arduino driven vertikal drive to allow for longer strokes. Your latest shots are marvelos like all times: Thank you!
Lothar
ploum
Post by ploum »
good luck ;)
ploum
Post by ploum »
600-700 picture for Nikon CFI PF 10x
Image[/img]
ploum
Post by ploum »
bendecamp
Post by bendecamp »
Frederic well done! I am a new fan of your work. Keep up the amazing images, I hope to get to your level soon. I photograph minerals too.
Ben
ploum
Post by ploum »
Thanks Ben,
and i'm waiting you :) in this small world
ploum
Post by ploum »
ploum
Post by ploum »
ploum
Post by ploum »
[/img]
