Mantis Fly
Mantis Fly
A contact of mine sent me some bugs from Florida. After a bit of a wash and a dry out on the window cill this fella cleaned up really well. This is the sort of insect i will never see alive in the UK and it is by far the weirdest looking critter i have ever seen.
Nice job! Very natural appearance for a dried specimen. I like the composition, background, and lighting. I see no stacking artifacts except what might be a bit of halo around the right eye.
See http://en.wikipedia.org/wiki/Mantispidae.What a strange insect... What is it?
Thank you Harold
Thank you Ben. The insect is 22mm in length and the visible area (the photo) is around 10mm.
Thank you crisarg.
Thank you Rik. I was surprised at it condition....it had a good bath though. I couldn't get rid of the halo. I tried retouching, cloning etc.....my PS skills are not 100% or even 50% come to think of it.
Would you happen to know what the law is concerning sending dead insects internationally?
Thank you crisarg.
Is the "halo" present in the original images? If it is, then it could be light from behind bouncing off the surface of the eye at a grazing angle, sort of like a hair light in portrait photography. In that case it's not a stacking artifact. If the halo is not present in the original images, then it also should not appear in a DMap output when the slider is adjusted so that unfocused background is ignored (goes black in preview).Keifer wrote:I couldn't get rid of the halo. I tried retouching, cloning etc.....my PS skills are not 100% or even 50% come to think of it.
- Yousef Alhabshi
The "halo" isn't present in any of the original images. I'm going to run the stack again and move the DMap slider around a bit....fingers crossed i can get rid of it. Thank you for the pointer.rjlittlefield wrote:Is the "halo" present in the original images? If it is, then it could be light from behind bouncing off the surface of the eye at a grazing angle, sort of like a hair light in portrait photography. In that case it's not a stacking artifact. If the halo is not present in the original images, then it also should not appear in a DMap output when the slider is adjusted so that unfocused background is ignored (goes black in preview).Keifer wrote:I couldn't get rid of the halo. I tried retouching, cloning etc.....my PS skills are not 100% or even 50% come to think of it.
