Erodius sp. 5x and 10x (thanks rovobeetle for the ID)
Hello,
Today I took a couple of shots of a beetle I have for a while; I do not know the species. (Erodius sp)
First shot is with mitutoyo 5x with morfanon 172mm as tube lens, magnification is 4.5x
101 shots with 0,04mm steps; few last shots have aperture closed, taken from a enlarger lens
Shot with 5DmII in EFCS mode with 3 led lamps
Full size
http://farm6.static.flickr.com/5056/554 ... 204b_o.jpg
The Stereo
http://img97.imageshack.us/img97/2898/e ... o2000p.jpg
Next one is same beetle, this time with the mitutoyo 10x and the morfanon, magnification is 9x
184 shots with 0,009mm steps, few last shots have aperture closed, taken from a enlarger lens
Full size
http://farm6.static.flickr.com/5097/554 ... dc38_o.jpg
The stereo, may look a bit weird as I removed somedust and it shows
http://img827.imageshack.us/img827/6672/stereo2000.jpg
Regards
Javier
Full size
The Stereo
Full size
Regards
Javier
Javier, the full size images look great. For the stereo, I think you accidentally referenced a thumbnail. Removing ".th" from the url, I found http://img827.imageshack.us/img827/6672/stereo2000.jpg which seems to be the correct image.
You're right, retouching was not friendly to this stereo pair. The retouched spots are pretty obvious.
For retouching stereo, sometimes it works well to retouch one image of the pair, then carefully clone the retouched spots from one image onto the other one, being careful to position each cloned spot so that it matches the detail around it. In Photoshop, it is easy to get the Y-coordinate exactly correct by watching the Info display. You have to choose the X-coordinate by eye, but if you start the cloning with a small feature near to the retouched spot, it works pretty well. Usually I cannot make the retouched spots completely invisible, but the cloning trick works much better than trying to retouch each image separately.
Thanks Rik,
I replaced the thumbnail with a direct link, also added the stereo for the 5x shot.
I will try to retouch stereos the way you say, spaecially with big dust spot it is a difficult task
I guess that preaparing well the specimen is the way to do it but sometimes I find it difficult to remove the dust, sometimes I even make things worst.
I was considering buying a pair of binoculars for this task, something like this one in ebay 130498460387
Regards
Regards
Thank you Rik, also when you get the right lighting much more detail is shown. Lighting is the thing I want to learn more about as I find it the more determinant in final image quallity. Also the mixture of DMap and Pmax in the 5x image has heleped to get more detail (I should work more with Dmap, to see if I finally can understand it)
Regards
Regards
- Craig Gerard
Javier,Javier wrote:...snip...few last shots have aperture closed, taken from a enlarger lens
Just to clarify, the "enlarger lens" used for the stopped-down shots, are you referring to an enlarger lense which has the elements removed?
Yes, without optical elements; I used to do it with my finite lenses (I copied it from morfa) but you had to be carefull with things like vignetingCraig Gerard wrote: Just to clarify, the "enlarger lens" used for the stopped-down shots, are you referring to an enlarger lense which has the elements removed?
With infinity lenses works much better, no vigneting at all. Aperture works like in a normal lens
Regards
Javier,
Your photos are fantastic! I'm especially impressed with the Mitutoyo 10x shots of this beetle (and the Tenebrio); like Rik says: a "wealth of detail...". If possible, could you please give more specific info on your tube lens setup with the Mitutoyo and morfanon (aperture type & position, distance between parts, adapters, maybe a photo?); any additional info would be greatly appreciated!
Thanks,
Eric
Thanks,
Eric
Glad you like it,
You can see my tube lens set up here
http://www.photomacrography.net/forum/v ... c&start=15
For aperture I use an old M39 AICO 50mm 3.5 without the optical elements. Front thread happens to be same as BD but the lens is a bit far from the Iris. This was more of a problem with finite BD plans, mitutoyos work very well, with no vigneting no matter the aperture setting
Distance from the mitutoy rear element to the tube lens is around 25mm
Any questions you may have just ask
By the way, at the end I bought a 45º binocular with 1x and 2x lenses and 10x and 20x eyepieces so I will have 10x 20x and 40x
It is mainly to prepare and have a look at subjects before working with them
Regards
Regards
