Here are 2 similar bees on 2 similar flowers. One taken with flash, one without.
Backyard Series #62 (flash or no flash?)
- Michigan Michael
Michael
D200, D300, or D2x
with
60mm Nikkor, 105mm VR Nikkor, or 180mm Sigma
D200, D300, or D2x
with
You didn't say what the weather was doing! First one could be bright sunlight, second one could be with diffused flash.
I know all about bright sunlight as it wreeks havoc on shots like this both with the bee and the echinacea.
Second one could also be done with no flash on a dull cloudy day, though I suspect not as the echinacea is a bit bright.
Perhaps it's not echinacea - I have the purple ones not the white ones so I don't know.
Unless you set out to deliberately fool us then no1 is definitely the flash shot. Are you using two flash units as there appear to be two distinct catchlights...
In this case I prefer the second image. I do normally prefer natural light to flash, but then again it /is/ possible to balance the two and use flash to enhance daylight rather than blasting over the top of it (not suggesting that's what you've done here, quite a nice job actually!)
I think the reason I prefer the second image is not to do with flash vs no flash, I think the bee is just in a better position, and the background is cleaner... I suspect at full size the flash shot might have more detail though!
- Michigan Michael
- Michigan Michael
