Field stack: inconspicious heteropterid
Fujifilm S5pro, Carl Zeiss Luminar 63/4.5, Nikon PB-6 Bellows, tripod
6MP version
This is a 5mm long heteropterid (I presume it's a juvenile but with some species it's a little hard to tell). It's stacked from 27 natural light exposures in Zerene Stacker (this bug proved to be an inconspicious but well behaved model).
The following gif-animation shows the 27 unedited (straight out of camera) frames:
Synthetic rocking sequence generated in ZS (DMAP, from -1.5° to +1.5°):
Cross eye stereogram:
6MP flash version: HERE
Thanks for viewing!
John-- A couple of questions
1. Did you immobilize that branch in any way? Or did you leave the entire area untouched and were just lucky to have no wind or other interference?
2. How many DMAP output images did you select between the -1.5 and 1.5? The rocking is so smooth. It looks like 7-9.
3. Did you retouch each frame going into the rocking gif, or again was it just luck that it was a subject without any overlapping areas that results in a near perfect pmax/dmap? Im just curious here, not really as important
Thanks!
Thanks!
Semper cogitatio
Graham
Graham
Thank you Rik and Graham,
Graham:
1) Yes I have a small tripod with one of those "helping hand" stands (with two crocodile clips – often used when soldering) mounted at the top. This allows me to fixate the perch – most of the time without causing any damage to the plant.
2) 15 (but it went pretty fast since I prescaled the input images to something like 10%)
3) No retouching was needed in the rocking sequence. It would have been too tedious to retouch 15 frames anyway. The cross eye stereogram renditions were slightly retouched though – I used DMAP as a base for both and painted in some areas from the corresponding PMAX versions.
Graham:
With Zerene Stacker it's easy: http://zerenesystems.com/stacker/docs/S ... Stereo.phpanvancy wrote: how did you generate the rocking sequence?
Lovely shots John - still can't believe how well the artificial stereos work
Brian v.
Brian v.
www.flickr.com/photos/lordv
canon20D,350D,40D,5Dmk2, sigma 105mm EX, Tamron 90mm, canon MPE-65
