My A7R4 has stopped working properly. I can no longer change camera settings either on the camera or with software. I tried doing the menu / reset routine but I can't get to the menu to do it. The display still functions, and it will still take a pic. If I change the mode dial, it ignores me, but will recognize the change after a power cycle, ie from P to A.
Is there some sort of lock-out that I inadvertently hit?
Is there another way to reset the camera? I read online about removing a button battery that holds the memory but it was general for Sony cameras and I can't find the specifics for the A7R4
I can't seem to find my owner's manual so was relying on the web, which so far has been no help.
Please let me know if you have any info on how to reset the A7R4.
Thanks...Ray
Edited to add: FOUND IT! The trigger cable was partially removed and apparently shorting the connection. Plugged it in and all's good again. Sorry for the trouble...
A7Rm4...how to reset? FIXED
Online
