Just found these from some googlin'
https://www.holmarc.com/super_long_work ... ective.php
Allegedly corrected for a whopping 42mm field, apo, long working distance and good NAs. And the listed prices aren't that bad, and they even have some unique styling.
A 5x/0.18, 40mm wd, 459 bucks?
A 25x/0.64 with 8mm wd?? For under 1k??
Huh.
Is that even possible?
Holmarc planapo objectives -- wide field, high na, priced lower than mitutoyos??
Re: Holmarc planapo objectives -- wide field, high na, priced lower than mitutoyos??
hmh
20x NA 0.35 WD 17 for 1659.-
25x NA 0.64 WD 8 for 959.-
10x NA 0.4 WD 19 for 814.-
10x NA 0.33 WD 16 for 933.-
why are lenses with better specs less expensive?
I'm afraid there are some type/translation errors on this website
can any infinite high NA lens be used as finite lens?All stated magnifications are based on a tube lens focal length of 200 mm. Mounting thread: M26 x 0.706 pitch (36 TPI). These objectives can be used in finite and infinite configuration.
Lots of questionable elements here for sure.
My guess on the finite/infinite would be that they're offered in bith options as Seiwa does. Doesn't deal with the other questions.
I emailed them for more information and got this reply:
We are sorry to inform you that we have discontinued the mentioned type of objectives due to the unavailability of lenses used in the system.
An unsurprising outcome I suppose--with specs like those they had to be full of crap.
